Old 21st April 2008, 11:16 PM   (permalink)
Default Voltage regulator
I'm building a hydrogen generator as an enhancer for my jeep. To make a long story short, I need a schematic for a variable voltage supply. The criteria is 0-1 volt. This will be used to test my circuit for the effi device that I have created.
I know this is probably a simple request ,but I'm just getting back into the electronics hobby. It's been about 35 years since I tinkered with this hobby. Any help would be appreciated.
Mike
camhar25 is offline
Old 21st April 2008, 11:34 PM   (permalink)
It takes a massive amount of power to make hydrogen. The engine will gain a tiny amount of power from the hydrogen. You probably don't want to spend a fortune on gasoline for the engine's alternator to make hydrogen.
If you manufacture hydrogen overnight using mains electricity then it still costs more than it produces.
audioguru is offline
Old 22nd April 2008, 10:10 AM   (permalink)
Mike - you need to determine the current requirements. Is the lowest voltage really zero? Simple 3 terminal regulators only go down to 1.25 volts - but can be arranged to provide the very low or zero to some value as an output.
stevez
stevez is offline
Old 22nd April 2008, 11:01 AM   (permalink)
Default regulator
Ineed to get at least below .5 volts and up to 1 volt to test my circuit. Any ideas on a setup?
Mike
camhar25 is offline
Old 23rd April 2008, 10:36 PM   (permalink)
Default Current
I'm trying to trick the computer in the car. The O2 sensor puts out a signal from 100 t0 800 Mv . I have created a device to set the voltage at 100 mv which will create a lean conditon. With the hydrogen supplement this will be fine. I need to test the device with the 0-1 volt reading.
camhar25 is offline
Old 5th May 2008, 01:43 PM   (permalink)
Did you try the pulsed electrolysis from Stan Meyer?
Instead of doing common electrolysis with poor efficiency, you can try making a train of short pulses. It seems that the efficiency increase.
G
giusepped is offline
Old 5th May 2008, 04:23 PM   (permalink)
Since the computer input is likely high impedance, all you would need is a pot (say 10k ohm) connected to a voltage reference such as a zener diode. 5.1V to 6.2V zeners are fairly stable with temperature. There are also many inexpensive voltage reference ICs that you could use for the best stability.
crutschow is offline
Analog Meter windozeuser General Electronics Chat 19 3rd October 2007 02:44 PM
600v to 3.3v voltage regulator kekek Electronic Projects Design/Ideas/Reviews 23 27th August 2007 04:02 AM
Current limiting Help PLZ Frosty_47 General Electronics Chat 32 24th July 2007 03:50 PM
Voltage spikes through voltage regulator? gregmcc General Electronics Chat 8 21st April 2007 05:41 AM
7.6 volts from a voltage regulator Electric Rain General Electronics Chat 12 27th August 2003 09:08 PM
