Old 19th April 2008, 09:27 AM   (permalink)
Wink What can i do with this
Hi i have take off one transformer from an APC UPS, and now i don't know what to do with it.
Can someone tell me if i can use this transformer for something useful like audio amp or etc. How powerful is it? Ideas?
DarkJoy is offline
Old 19th April 2008, 10:22 AM   (permalink)
What was the power (VA) rating of the UPS, and what was the voltage of the battery they used?
mneary is offline
Old 19th April 2008, 12:22 PM   (permalink)
If APC is an Armoured Personnel Carrier you might as well forget about the tranformer. They work on 400Hz.
Boncuk is online now
Old 19th April 2008, 12:47 PM   (permalink)
Default APC model
This is the UPS:
http://www.apc.com/resource/include/...TOKEN=52816945
DarkJoy is offline
Old 20th April 2008, 09:25 AM   (permalink)
Could you post the weight of this transformer to confirm that it's the main unit? (Or, a photo against a ruler/scale.)
If this is the only power transformer, it should be able to transfer 600VA intermittently and 200VA continuous. It would probably have (insert your mains voltage here) to 12VCT, plus other windings that will produce about (insert your mains voltage here) from the battery.
I really hate it when I have to guess where a person is.
mneary is offline
Old 20th April 2008, 10:00 AM   (permalink)
It weights ~4 Kg and it's dimensions are ~10cmx10cmx10cm...
I'm newbie in electronics, but if i have any project in what i could use this unit i would give it to my friend who is better in electronics, Thanx
Mainly i'm interested in making sub-woofer AMP... or maybe 2x stereo amp.....
Or should i search for another transformer??
DarkJoy is offline
Old 20th April 2008, 10:18 AM   (permalink)
The mass and size confirms that this is the main transformer. We believe that it's good for 200+ VA continuous, however your friend should check what voltages it actually produces. Typical voltages in this applications aren't optimum for audio amplifier systems. This transformer is targeted for 12V (14.4V to charge the battery) on the secondary, while audio systems are expected to be 4-8 ohms. (200 watts into 8 ohms normally would use +/- 40 volts DC.)
mneary is offline
