I am looking for a single phase rectifier with a blocking voltage of at least 30V, current rating of 300A or greater, and a forward voltage of .25V or less. Does anyone know where I could find something like this or if they even exist?
Sam |
Experienced Member
What are you trying to do? Because no one runs 300A at 30V. You run it at 300V at 30A to reduce the current which reduces the losses.
Is this 300A continuous? Or stall? Because if it's continuous, then what I said above applies. If it's stall, then you need the continuous rating.
NO, that picture isn't me so don't bother asking if we can be friends. |
Experienced Member
SPB16080 & DSS2x110-80A Schottky dual 160 amp. Will not do 0.25 volts!
300U5A, 300U5AMA, 300U5AM 300A 50 VOLT (Vishay IR) 306CNQ200 SPB160100E3 (Microsemi) I do not see anything that will make the 0.25 volts! At these current levels you should try MOSFETs used as diodes. IRF2804strl7pp 40 volt 320 amp 1.6mohm (you will need to parallel two to get you forward voltage spec.) IRF1324S 24V 429A 1mOHM |
I am trying to run a high current, low voltage electrode. The 300A is continuous. I have noticed that not many people run at these levels, otherwise this component would be easier to find.
Experienced Member
NO, that picture isn't me so don't bother asking if we can be friends. Last edited by dknguyen; 18th April 2008 at 02:11 AM. |
Experienced Member
Wild guess: homemade welder?
Torben |
Super Moderator
Well, yet again he's not got his location filled in, but 300A at 30V is 9000W, three times what you can get from a normal single phase socket in the UK.
Experienced Member
Torben |
Experienced Member
You can do it using an active rectifier.
An active rectifier works with power MosFets which you can parallel to obtain the desired current at very minimal losses, well below 0.1V per "diode". I have experimented with an active bridge rectifier using N and P-channel power MosFets. The circuit worked, but not to my satisfaction. The problem is: N and P-channel MosFets have different RDSON values which makes it almost impossible to obtain a safe rectified voltage. One transistor out of tolerance causes huge shorts switching N and P simultaneously. (just half way is enough for St. Elmo's fire. A two-way rectifier doesn't have those problems. The circuit is going to be published in Elektor magazine in July/August 2008. Give me PM and you might get the circuit in advance. Best regards Hans |
Why not parallel 3 >100A silicon rectifier diodes?
does active rectifier with mosfet exist in single chip replacing classic bridge diode, i would need approx 50A capacity at 30V?
Experienced Member
300a diodes are used in battery chargers for forklift . The batteries I'm referring to are 48 volt and weigh in at about 3,000 lbs, don't remember the a/h capacity..The primaries of the chargers are fused 30a at 480volts.. Not sure of the voltage rating of the diodes either, probably 200 or so. We purchased replacements from the manufacturer, are they were 75 miles down the road from us (Clarklift of Middle Tenn.). I'm sure they weren't cheap either, as none of thier parts were..
gerty |
What I am trying to do is take 300A at 30V AC and turn it into DC while minimizing voltage drop. I've been told that a gallium rectifier has a forward drop of 0.35V but they are expensive. That could work if I can find one. Another option could be a selenium rectifier. Does anyone know what the forward drop on a selenium rectifier is?
Super Moderator
Experienced Member
| Rectifier with unity power factor | yuchween | Electronic Projects Design/Ideas/Reviews | 18 | 16th January 2008 11:30 AM |
| Will a rectifier diodes work as protection diodes in a relay app? | Andy1845c | General Electronics Chat | 12 | 15th November 2007 09:42 PM |
| Peak Rectifier Problem | xmat | Electronic Projects Design/Ideas/Reviews | 8 | 22nd July 2005 05:35 PM |
| 3 Phase Rectifier | IRQ57 | Electronic Projects Design/Ideas/Reviews | 14 | 8th September 2004 12:23 AM |
| Bridge Rectifier Current Rating -- How much is enough? | hamfiles | General Electronics Chat | 6 | 6th August 2003 06:15 AM |
