Old 23rd April 2008, 09:31 PM   (permalink)
Experienced Member
Originally Posted by sammyb11
I am looking for a single phase rectifier with a blocking voltage of at least 30V, current rating of 300A or greater, and a forward voltage of .25V or less. Does anyone know where I could find something like this or if they even exist?
Sam
Somehow I don't think you'll be able to find anything with a forward voltage of less than 250mV at 300A, a huge Schottky rectifier maybe?
Old 24th April 2008, 12:03 AM   (permalink)
Experienced Member
john1 is a jewel in the roughjohn1 is a jewel in the rough
Hi Sammyb11,
I do not think there are any rectifiers which will meet those requirements.
If i had to meet those requirements, that is a forward resistance of around O.OOO8 ohms
then i would be considering a small sychronous motor running a set of paralleled brushes
on a purpose made commutator.
I personally think that this poster is going about something the wrong way, as Dknguyen
has already mentioned.
Boncuk mentions using power MosFets as surrogate diodes, presumably zero-crossover switching
and driven hard, so as to maximise conductivity.
Boncuk also mentions that this type of arrangement has inherent problems which in his
opinion made it difficult to set up satisfactorily.
However he was referring to a "bridge rectifier assembly", the poster here is looking for
a "single half-wave asembly", such an arrangement may not have the problems that Boncuk
mentioned.
I don't recall what RDSON means, but it may very well not apply to a half wave set up.
Making such an assembly using MosFets, would require at least basic constructor skills
and some understanding of how MosFets work, and how to make and set up the driver circuitry,
and probably use of an oscilloscope when setting up the zero switching.
And it would not be cheap.
Making a sychronous set of brushes is easy to understand, and more could be added to get
the resistance down to an acceptable level.
Most constructors could make such an assembly.
It is dificult to give this poster a reasonable answer which addresses his needs, as he
has only given what he considers to be what he wants for his job.
It is of course possible that Sammyb11 knows exactly what he wants to achieve, and that
a 30 Volt, 300 Ampere, diode with a max forward voltage drop of O.O25 V, is in fact the
most appropriate way to do it.
Best of luck with it, John
john1 is offline   Reply With Quote
Old 24th April 2008, 07:50 PM   (permalink)
Experienced Member
Super_voip is on a distinguished road
Selenium rectifiers have a serious leakage problem, they are also very bulky.
If you are looking at older tech there was a mercury rectifier which could handle very very large currents, they were used to rectify power for trams.
Super_voip is offline   Reply With Quote
Old 25th April 2008, 12:14 AM   (permalink)
Experienced Member
Analog has a spectacular aura about
Power Germanium Rectifier? Still probably won't get down to .25V.
"Everything that is done in the world is done by hope." -Martin Luther
"There are two ways to live your life. One is as though nothing is a miracle. The other is as though everything is a miracle."-Albert Einstein
Analog is offline   Reply With Quote
Old 25th April 2008, 12:22 AM   (permalink)
Experienced Member
Torben is a name known to allTorben is a name known to allTorben is a name known to allTorben is a name known to allTorben is a name known to allTorben is a name known to all
In Victoria there is a cool store called Capital Iron, which has an antiques section in the basement. They have one of these beasts, which together with its mount must be around 2 meter tall. It's a huge glass bulb with various protuberances and some charring from years of use, and they have some documents explaining what it was used for. IIRC this one was used for a subway or tram system like you mentioned.
I'd never even suspected the existence of those things before. That is one impressive bit of kit. I'd *love* to see one powered up. Apparently they are still in use.
Torben
Torben is online now   Reply With Quote
Old 25th April 2008, 12:55 AM   (permalink)
Experienced Member
mneary is a glorious beacon of lightmneary is a glorious beacon of lightmneary is a glorious beacon of lightmneary is a glorious beacon of lightmneary is a glorious beacon of light
Send a message via AIM to mneary
Has anyone seen sammyb11 recently? Did we answer your question?
mneary is online now   Reply With Quote
Old 25th April 2008, 03:26 AM   (permalink)
Experienced Member
the tram museum in Brisbane does have them running, think large electric arc, bottled lightning.
http://www.brisbanetramwaymuseum.org/photom25.html
Rectifier with unity power factor yuchween Electronic Projects Design/Ideas/Reviews 18 16th January 2008 11:30 AM
Will a rectifier diodes work as protection diodes in a relay app? Andy1845c General Electronics Chat 12 15th November 2007 09:42 PM
Peak Rectifier Problem xmat Electronic Projects Design/Ideas/Reviews 8 22nd July 2005 05:35 PM
3 Phase Rectifier IRQ57 Electronic Projects Design/Ideas/Reviews 14 8th September 2004 12:23 AM
Bridge Rectifier Current Rating -- How much is enough? hamfiles General Electronics Chat 6 6th August 2003 06:15 AM
