| Right suppose i have a main transmitter (rig) remotely linked with STl to get the audio to it Either band 1, 3, or x band) I need to remotely switch the rig on and off. This is what i have though of doing. Using a DTMF receiver chip to trigger an electronic latch which will then hold the relay to switch my rig. (i.e. one pulse from the DTMF receiver rig goes on. Another pulse from DTMF receiver rig goes off toggling the latch and therefor the relay). Ok thats fine and will most probably work but... What are the chances of whilte noise or audio/speech/music accidently triggering the remote latch circuit? example i could use 697 Hz and 1209 Hz sent down the audio link to toggle the relay/switch rig on/off. obviously having some DTMF generator sent down the audio link. Would this be an acceptable way of doing it? Hope someone can help with this one or maybe suggest an alternative. | |
PIC's are the way to go!. | ||
| Yeh agreed maybe i'll try that but with using DTMF a mobile phone could just be used down the mic. Easy! and the receiver would cost £2 max with the relay. I'd like to try this first since i have all the stuff. I dont have a pic programmer at home either. What do you think about it being accidently triggered though? what are the chances of white noise or audio doing that? thanks | |
| Yeh i suppose it will. Well, i'll try it today. | |
| 30 years ago, DTMF receiver ICs had a spec in the datasheet called, "talkoff" where speech would cause random decoded DTMF outputs. It occurs a few times per minute. It would probably occur more often with loud white noise.
| well i built/tested it today and works well over a wire so it should work over a link (thats for another day). I played some music through it and it didnt trigger it so hopefully this should work. | |
| DTMF remote control circuit | mytech | Electronic Projects Design/Ideas/Reviews | 0 | 7th January 2008 04:54 PM |
| Radio Remote Control Using DTMF | Nhan | Electronic Projects Design/Ideas/Reviews | 3 | 23rd August 2007 08:24 PM |
| need help building a radio remote control using DTMF | umarsani | Electronic Projects Design/Ideas/Reviews | 1 | 28th May 2007 10:32 PM |
| Remote Keyless Entry for Car | tim_l_012 | General Electronics Chat | 4 | 23rd February 2004 12:38 AM |
| help for : DTMF remote control with mt8880 | Pat-21 | Electronic Projects Design/Ideas/Reviews | 1 | 10th July 2003 04:49 AM |
