+ Reply to Thread
Page 2 of 2
First 1 2
Results 16 to 19 of 19
Thread: Display running engine vibrations.
  1. #16
    john1 Good john1 Good
    Join Date
    Jan 2003
    Location
    RW
    Posts
    1,249
    Hi Crutschow,
    I had not thought of using a spectograph for this. I should have really, cos now
    i think thats one of the diagnostic pieces that were used at the research place
    where i used to work.
    And yes, there are some free programs for these out there. So yes, that would be
    a good start, to get one of those rigged up and working.
    That is an excellent suggestion, and i will start looking at ways to do this first.
    I will check out that link you posted.
    John
  2. #17
    Join Date
    Jan 2003
    Location
    RW
    Posts
    1,249
    Hi Stevez,
    your post confirms the value of this type of display, but i suspect that it will
    not be easy to interpret the information, as i wont be able to fit sensors directly
    to the bearings.
    There are free downloads for this type of program available, so i will be sorting
    stuff out to get a PC running out in my little garage, and looking at various
    transducers, accelerometers, maybe microphones.
    And maybe a small pre-amp to drive the 'Mic' input.
    John
  3. #18
    Join Date
    Jan 2003
    Location
    RW
    Posts
    1,249
    Hi Nigel,
    That sounds very similar to what i have in mind.
    I had not considered monitoring temperatures around the engine, and if i did then
    it would be with small fixed sensors. Those IR types are way out of my price
    range.
    John
  4. #19
    The Mad Professor Okay
    Join Date
    Mar 2006
    Location
    Newent England
    Posts
    315
    Regarding sensors you might want to look at Piezo transducers.
    Normally used as sounders / loudspeakers in everthing from greetings cards to cell phones,
    however they do work the other way as well and make for very effective vibration sensors.
    Small, cheap and impervious to dirt and oil contamination and tough enough to survive inside the harsh enviroment of an engine bay.
+ Reply to Thread
Page 2 of 2
First 1 2
  1. Problem with LCD code?
    By spondootre in forum Micro Controllers
    Latest: 29th April 2008, 09:15 AM
  2. calculator
    By chinmay7 in forum Micro Controllers
    Latest: 14th October 2007, 12:45 PM
  3. microchip application A590 /display is ok now
    By prosound90 in forum Micro Controllers
    Latest: 18th November 2006, 09:44 PM
  4. running message display
    By marsvoltaire in forum Electronic Projects Design/Ideas/Reviews
    Latest: 5th February 2004, 06:02 PM
  5. Engine RPM Counter/LED Display
    By minhs in forum Electronic Projects Design/Ideas/Reviews
    Latest: 23rd October 2003, 08:05 PM
Tags for this Thread
