Old 16th April 2008, 06:31 PM   (permalink)
Default MIDI alarm powered blinking LED's
Okay, so I thought I figured out an easy way to make this circuit for a lucid dreaming mask. (I'm still looking into programming the parallel port of my computer, but I'd like to make something smaller).
I figured I'd use a headphone plug and plug it into my palm pilot, this will go to the base of a transistor (2N3904 from Radio Shack) which will direct 9V to the LED's when the alarm goes off.
For some reason however, my circuit isn't working. The LED doesn't blink when sound comes from the palm pilot.
I've attached a diagram of my circuit. Can anyone see what I'm doing wrong?
unseen wombat is offline
Old 16th April 2008, 06:51 PM   (permalink)
hi again.!
The LED needs at least 2V across it to work, add to this the 0.7V to switch the transistor ON, means that the palm output has be greater than +2.7V.
Which is unlikely.
Any help.
EDIT: try putting the LED resistor in the transistor collector, then you need only greater than +0.7v. add a 100R resistor in series with palm output to the transistor base.
Eric
"Good enough is Perfect"
PIC tutorials:
Gramo's: www.digital-diy.net/
ericgibbs is online now
Old 16th April 2008, 07:22 PM   (permalink)
Hi Eric. Thanks. Okay, unless I misunderstood, I just tried your suggestion. I think you meant that I should take the LED off of the emitter side of the transistor, and put it on the collector side, right?
If that's what you meant, it didn't work either. Could it be that my palm pilot just doesn't have enough juice to even turn on a simple little transistor? When I use headphones with it, it's enough to blast my ears off though.
Old 16th April 2008, 07:30 PM   (permalink)
Its sounds like your palm output hasn't got enough uumph!.
You may have to amplify the output before you try to light the LED.
Perhaps audioguru has some info on the output of a palm unit.???
Eric
PIC tutorials:
Old 16th April 2008, 10:24 PM   (permalink)
crap. You're right. I tested the output of my palm pilot with a multimeter. I have about .4 volts and .02 mA.
So how do I amplified signal?
Any suggestions?
Old 16th April 2008, 11:47 PM   (permalink)
Try this circuit to drive the LED.
When there is no audio then the input is at 0V and the diode's forward voltage is about the same as the transistor's base-emitter junction's voltage so the transistor is barely turned on.
When the signal swings positive a little then the transistor turns on and lights the LED.
audioguru is offline
Old 17th April 2008, 03:25 AM   (permalink)
Verrrrry smart. Thanks! I can see how that would work. Isn't the reversed diode preventing my audio input from going into the base though?
Sorry I'm not too smart about electronics stuff.
Old 17th April 2008, 08:00 AM   (permalink)
hi Trevor,
As 'agu' says when the output from the palm is 0V then the diode virtually switches OFF the transistor. [ a transistor requires about 0.7V between base and emitter to turn it ON]
When the 0.4V is output from the palm, the path for the base biassing resistor goes to 0v via the +0.7v of the diode and the 0.4V of the palm, that is 1.1V. The current via the base resistor now flows into the base of the transistor and makes it conduct.
Lets know how it goes.
Eric
PIC tutorials:
Old 17th April 2008, 01:13 PM   (permalink)
Okay, I'll go get some of those 1N4148 diodes at lunchtime, but let me try to understand how this will work. The 1N4148 diode keeps the current going through the 5k resistor from going back up into my audio jack, right? Because the forward voltage across the diode is less than it's turn on voltage? Then when there's audio output, the reverse voltage is enough to turn on the diode in reverse and send some current into the base. I'm looking at the data sheet for the 1N4148, and it looks like the max reverse current is like a few nanoamps. That won't be too little to turn on the transistor?
Old 17th April 2008, 01:48 PM   (permalink)
The base current for the transistor flows via the resistor from the battery.
If the palm output is low [0v] then this current flows to 0V thru the diode.
This flow causes a 0.7v drop across the diode, this 0.7V turns ON the transistor slightly. [as agu explained]. LED very dim.
When the palm outputs the 0.4V the diode becomes reversed biassed and stops conducting to 0V. All the base resistor current now flows into the transistor turning it hard ON, LED full glow.
So its not the reverse current thru the diode.
Is this explanation OK.?
Eric
PIC tutorials:
Old 17th April 2008, 02:00 PM   (permalink)
I hope the forward voltage of the diode and of the base-emitter junction of the transistor match. If your LED is turned on or turned off most of the time then try another diode and/or transistor.
The current in the transistor and in the LED should increase a lot when the input voltage from the palm rises only 0.1V.
Old 17th April 2008, 06:55 PM   (permalink)
Okay, I just tried it. It only left the LED in the "on" state the whole time. It didn't fade or intensify or anything.
Except... and this was interesting, when I turned the device on or off (I was using my PSP rather than my palm pilot this time, because I left my palm at home), the LED turned off, and then back on. I don't see any reason for that. It doesn't make a noise when on, unless there's some residual EM waves creating some noise in the headphone output, but then after it's off, why would the LED come back on?. And it doesn't make a noise when it's turned off. Strange.
I checked the diode with my diode checker on my multi-meter. In reverse it read OL, obviously, and in forward, it was 0.69, like I expected. I don't know if this means anything at all, but when I put the diode checker on the transistor base and emitter, I got a reading of 1.828. Does that mean the transistor's turn on voltage is 1.828V? If so, would putting a resistor in series with the input diode help boost up the voltage?
Just some thoughts.
If I'm going to have to be collecting a half dozen components for this thing though, do you think it might be easier to just use 2 resistors and a single 741 op amp and make a simple non-inverting amplifier? Would that work?
Old 17th April 2008, 07:16 PM   (permalink)
My simple LED driver circuit needs to be fed from an audio source that has DC coupling to ground. Yours probably has an output coupling capacitor so the voltage was at 0V only when it was first connected.
My circuit can be driven from the output of an opamp if it can go to 0V. Most opamps need a dual polarity power supply to go to 0V.
Old 17th April 2008, 08:53 PM   (permalink)
Oh. Well I don't know what to do then. Is this just impossible without two 9 volt batteries, an op amp, transistor, and a half dozen various components?
I had a leftover 741 op amp and tried to make a simple non-inverting amplifier, but the LED just stayed on the whole time. I then tried to make a comparator, using a variable resistor to adjust the voltage into the inverting input and the audio input into the non-inverting input, but the LED just stayed off.
I can't believe making an LED blink in time to sound is such a difficult task.
Old 18th April 2008, 08:05 AM   (permalink)
The 741 is an old, low spec device
Did you try to use the 741 as a comparator.?
Look at the LM392 ic datasheet, its a opa and comparator in one package.
Its oldish, but you not looking for 'quality' of the audio, just a 'ac' amp and a level detector/comparator to flicker an LED, using a single 9Vbty.
Eric
PIC tutorials:
Question about Inchworm+ Quan Micro Controllers 54 28th October 2007 01:21 AM
Introduction to High Brightness LEDs and Thermal Management Ocelaris Electronic Projects Design/Ideas/Reviews 3 17th March 2007 06:35 AM
I want to improve my remote car alarm system. Turbo_Boss Electronic Projects Design/Ideas/Reviews 2 4th January 2007 10:27 PM
Problems with Dual Brightness (Current) LED Tail Lights? Eagle Schematics! Ocelaris Electronic Projects Design/Ideas/Reviews 12 31st December 2006 07:18 PM
blinking leds sb42 Micro Controllers 2 6th July 2006 02:41 PM
