| Experienced Member | I have successfully used an old 220 / 5 or 8 volt TX and wound a couple of turns of 1.5 mm² wire around the core. The 8 volt or the 220 volt output can be used for the measuring circuit. In case of the 220 volt winding, put a resistor 100 or 470 ohm ½ watt across the terminals. A CT does not like open circuit voltages across it's terminals. I used above system to check my outside security lights. lamp ON, LED ON. circuit working OK. The LED is directly driven from the CT - TX. with an antiparrallel diode (1N914). I made up 4 of these CT's to measure all 4 outside lights.
__________________ There are more ways to get to Rome. Electricity, Electric clocks, Meters and Trains are great. |
| Experienced Member | Quote:
Thx again... Last edited by jbarnaby2000; 6th May 2008 at 07:30 AM. | |
The ratio should be about primary:secondary=1:10. Hans | |
| Experienced Member | I use my circuit to detect a current flow in an AC circuit. Current flow, lamp working, CT secondary drives LED on indicator panel in my hall. In commercial metering proper CT's are used. These are mounted at a link section in the main busbars of a switchboard. Ratios may vary from 50/5 to 2000/5 Amps. Generally these CT's have a seconday of 5 Ampères which will drive the kWh or kVArh metering via a testblock. The voltage potential is directly taken from the busbars via potential fuses. On high tension sites also voltage transformers are used and the metering potentials generally run on 57½/100 or 63/110 Volts. These values ascertain safe voltages on the metering equipment and create easy multipliers on 10 and 11 kV systems or multiples thereoff. The yellow phase is usually earthed at the secondary of the VT.
| New Member | JBaraby, Did you ever get the circuit figured out? I'd be very interested. I have a similar interest. Want to use a CT to measure current (0-5 A) on a motor to detect a jam condition using an a/d on a pic micro controller. I need a circuit to convert the AC volt to DC Volt (0- 5 VDC) for the pic input. found this at the CR micro site. http://www.crmagnetics.com/pdf/ancrct-4.pdf Any help would be appreciated |
It looks like that is a great solution to the current measuring solution I was looking for...the only thing, the application note above does not give you is any information on the zener diodes....any one have any ideas or suggestions on which zener's to use in that circuit?? Thx | |
It should be noted that the circuit in the ap note generates a DC voltage equal to the peak of the AC waveform which is not a particularly accurate way to monitor power. Any noise or distortion (such as from dimmers) will give an inaccurate reading. To get the average (not as good as RMS but better than the peak), move the output resistor from ground and connect in series with the output filter capacitor. Note that this resistor should be at least 10 times larger than the sum of R4 and R5. | |
| Experienced Member | Any reason not to use this convenient $3 part? http://www.allegromicro.com/en/Produ.../0713/0713.pdf |
| New Member | The techs at CR Magnetics have been helping me with the values in the circuit. The CR8410 saturates at greater that 2 V. Recommended R1=20 ohm for a voltage of about 100 mV at a primary current of 5A. (Note that the 8410 has a compensated turn ration of 1012). R2=R3=10K. R4=10K R5=500K I was thinking of using a 470K with a 100K mutliturn trim resistor in series for R5 so that I can adjust the gain. Final reistor and capacitor act as a filter. They recommended a 10K with a 4.7 microfarad cap. see diagram at: http://www.crmagnetics.com/pdf/ancrct-4.pdf Last edited by tyru; 8th May 2008 at 04:52 PM. |
| Expert Stabilised Power Supply with Current Limiting | mechie | Electronic Projects | 36 | 11th March 2008 07:16 PM |
| Current Shunt Question.... | Rescue1 | General Electronics Chat | 1 | 20th July 2007 08:49 AM |
| Measuring current with current probe | naseeam | General Electronics Chat | 1 | 19th July 2007 08:58 PM |
| Current and Conductivity | ElectroMaster | Electronic Theory | 1 | 2nd February 2007 12:49 PM |
| Will this work? | daviddoria | Electronic Projects Design/Ideas/Reviews | 31 | 9th May 2003 04:43 AM |
