Old 13th April 2008, 02:06 PM   (permalink)
Default Switch Tansistor
Sorry for asking stupid question like this, i just wanna comfirm am i right about the connection of these simple circuit.
wat i wish is to use a 5V signal to trigger a 24v input.
My control signal is 5V which i will connect to the transistor base with resistor in series, then i supply a 24V source to the collector with resistor in series as well.
So wat i wanna ask is:
1) is the way i connect this circuit correct?
2) where should i connect my output device, at the collector or emitter?
3) wat value of resistor i should be using and can i use transistor 9013?
Thanks for ur time reading and help.
ungck is offline   Reply With Quote
Old 13th April 2008, 02:14 PM   (permalink)
You need to tell us what the load is.
But with that circuit configuration it needs to be in the collector.
You might look at the "Hardware Extras" part of my PIC tutorial, which covers this sort of thing.
Old 13th April 2008, 04:03 PM   (permalink)
Actually i am trying to activate a valve with 24V, so i don think i load would affect much. If it is connected to collector, is it the +ve of valve to collector and -ve of vale to the emmiter.
And can 9013 support this?
Thanks for ur help, i really do apppreaciate it.
Old 13th April 2008, 04:30 PM   (permalink)
hi.
Refer attached datasheet.
If the solenoid valve is 24V dc operation, it would be connected with +V end of the solenoid to the +24Vdc power supply and the -V end of the solenoid would be connected to the collector of the transistor.
The problem is you have not told us the current required by the solenoid or its resistance. This would determine if the current rating of the transistor is high enough for the solenoid.
If you drive a solenoid with a transistor you MUST have a clamping diode across the solenoid.
Do you follow this.?
Eric
"Good enough is Perfect"
PIC tutorials:
Gramo's: www.digital-diy.net/
Old 14th April 2008, 11:16 AM   (permalink)
i think i get wat u mean. i did try to connect the solenoiid valve at the collector with a diode parallel to it and it do works.
Thanks for ur help
Touch Sensitive Switch (Take 2) MonkeyMera Electronic Projects Design/Ideas/Reviews 7 2nd October 2007 10:05 PM
Button Debounce Coding help Suraj143 Micro Controllers 25 4th August 2007 09:48 AM
Please help me in writing code abdosat2000 Micro Controllers 9 5th June 2007 01:40 PM
PIC Switch Management Techniques Mike, K8LH Micro Controllers 2 28th September 2006 12:33 PM
How to configure this On/Off Switch with Bicolor LED?HELP ME Stimulation Electronic Projects Design/Ideas/Reviews 10 23rd April 2003 04:55 AM
