Old 12th April 2008, 02:46 PM   (permalink)
Default Relay and timer
Hi
I've build a very simple circiut with a 12V / 220V relay.
When the relay gets an 12V signal, it triggers the 220V.
Now I want to add an timer to this relay, so when there is an 12V signal, an timer sends a variable signal (3-10s) to the relay.
So everytime the is a 12V signal, the relay will be triggered for some seconds.
Does anyone know how I could make this? and what parts to use ?
TCDK is offline
Old 12th April 2008, 05:00 PM   (permalink)
http://www.electronics-lab.com/proje...014/index.html
The 555 will supply 200mA maximum current for the relay coil. If the relay coil requires more current you will need to add a reaistor and transistor to increase the drive.
Ken
KMoffett is offline
Old 15th April 2008, 08:38 AM   (permalink)
Uh thanks! looks very easy!
TCDK is offline
Old 15th April 2008, 07:14 PM   (permalink)
One thing I dont get with this schematic.
"pin 1" is GROUND on a 555, why should this be connected to 12v + ?
TCDK is offline
Old 15th April 2008, 07:31 PM   (permalink)
Maybe I'm misunderstanding you, or you're misunderstanding "Ground". The "Ground" on the 555 (pin 1) goes to the negative side of the 12v supply. The little upside-down pine tree symbol at the bottom is "Ground", and the negative side of the 12v supply.
Ken
KMoffett is offline
Old 15th April 2008, 07:33 PM   (permalink)
Pin 1 is connected to ground/0V not +12V ....
Eric
"Good enough is Perfect"
PIC tutorials:
Gramo's: www.digital-diy.net/
ericgibbs is online now
Old 15th April 2008, 10:28 PM   (permalink)
Ok, I draw it in Eagle, and now I understand
This is my first schematic drawings, so they are a little messy.
If anyone would like to put it better together it would be great.
See what im talking about
and the board:
EDIT: This is how I made the board now:
The sch file = layout_01.sch if anyone would like to play around with it.
TCDK is offline
Old 16th April 2008, 10:19 AM   (permalink)
I tryed to set it up on a hole island board.
First time I powered it up, with a wrong connection.
Is there anyway I can check if there are any parts that have been fried?
Does the above board seem ok? it dosen't show any faults when testing in Eagle.
TCDK is offline
Old 16th April 2008, 08:35 PM   (permalink)
Got it to work now.
Only thing, if I turn up to trimmpotmeter over ~3sec, it dosen't release again.
Think maybe the trimm is broken - I will get another one soon.
Now it's only the print making left.
TCDK is offline
Old 21st April 2008, 05:11 PM   (permalink)
Now I got this up and working, but would like to add an little extra feature.
The contact/switch will in my case be a floatswitch.
I would like to make something where I can ensure that if the floatswitch is somehow stuck, I wont keap sending and signal to the relay.
Aka. if the 555 timer gets an on (holding) signal that isen't released again the 555 wil cut of the signal to the relay as it should.
Now it just tricks the relay and keep it on (if I hold the switch on forever)
So maybe the 555 should have an signal there is cut of between the switch and the 555, or can the 55 somehow be set to only trigger once ?
TCDK is offline
Relay control using timer IC and micro-controller HiteshDR Micro Controllers 2 24th November 2007 06:24 AM
Making a relay delay electronic board??? cloudkicker101 General Electronics Chat 7 10th March 2007 01:58 AM
Time Delay Relay Circuit.....is this doable? Draguen General Electronics Chat 14 31st August 2005 05:02 PM
Looking for a DPST relay with 15-minute timer vandy33 Electronic Projects Design/Ideas/Reviews 6 2nd February 2004 11:15 PM
555 timer with a relay crchisholm Electronic Projects Design/Ideas/Reviews 3 30th June 2003 09:25 PM
