Old 11th April 2008, 07:24 AM   (permalink)
Default Need Help! A circuit that will produce only 1 pulse
Hello.. anyone can help me? I'm trying to design a circuit that will only produce a SINGLE PULSE with T_HIGH period.
Or.. how can i make a 74HC390 to reset forever when it reach 0010 state? Because i just need the pulse from 0001 state. In other word, i just need 1 short pulse. This pulse will not be triggered by any other signal.
menirva is offline
Old 11th April 2008, 11:56 AM   (permalink)
You can use LM555 timer in Monostable mode to produce one pulse.
See
http://home.cogeco.ca/~rpaisley4/LM555.html#2
http://publico.ing.ues.edu.sv/asigna...20Tutorial.htm
Hope that will help.
Abeer_engjbr is offline
Old 11th April 2008, 01:43 PM   (permalink)
This will produce a single pulse. Its main purpose is a debouncer. It does not give a secondary pulse when the switch opens or is kept closed. Pulse duration is set by C2/R2.
John
jpanhalt is offline
Old 15th April 2008, 12:19 AM   (permalink)
Thanx! The switch can be any oscillator? Can you help me, i tried on p-spice, but i may have done something wrong here?
menirva is offline
Old 15th April 2008, 04:04 PM   (permalink)
What's wrong with a thyristor?
A conclusion, is the point reached when you stop thinking.
Centretek is offline
Old 15th April 2008, 05:10 PM   (permalink)
How do you turn it off, if the current is still flowing? You could use a GTO device, but then you still have a circuit about as complicated as the other options.
John
jpanhalt is offline
Problem measuring pulse width - 12F683 TMR1, 8MHz jess Micro Controllers 18 5th February 2007 11:00 AM
Ultra low power switching circuit & DC to DC converter t fastenjaw Electronic Projects Design/Ideas/Reviews 15 16th November 2004 10:57 PM
The ECG(heart Pulse) circuit problem... kingkong83 Electronic Projects Design/Ideas/Reviews 15 11th October 2004 07:48 PM
Fuel injector pulse detector brjones Electronic Projects Design/Ideas/Reviews 3 31st August 2004 09:07 PM
Pulse Width Calculation waqar Micro Controllers 1 25th June 2003 12:54 PM
