| I need some advice about connecting a two-lead electret condenser mic (which I’m about to order) to a preamp, the final design of which is yet to be settled upon. (I have a two-transistor preamp, but I have a nice little circuit for an op-amp preamp that I may build.) Because I have a 12VDC power source available near the preamp, I’m using that to power it. (A small amount of hum is acceptable in this application.) Most ECMs are rated for around 2—3VDC up to a max of 10VDC, and I understand that a current limiting resistor in series with the power is necessary…usually noted as 1k ohms or 2.2k. The 10 volts max limit would seem to rule out my 12 volts idea. On the other hand, I read something elsewhere that says to use the higher 2.2k resistor if the voltage source exceeds 12 VDC. Now I’m thoroughly confused about whether or not it’s a good idea to try to use 12 volts. If it’s possible but hard on the ECM, I’d rather try to reduce the voltage to the ECM. Does a voltage divider seem reasonable in this situation? The ECM uses about .5mA. Perhaps a couple of 12k resistors in series to ground, and I could tap 6VDC from between them? Thanks Last edited by Ventura; 11th April 2008 at 05:06 AM. | |
| Most electret mic operate at 0.5mA so a 10k resistor from 9V is fine. You should use a 4.7k resistor from 12V to feed the 10k resistor with a 100uF filter capacitor to ground where the resistors join. The filter avoids motor-boating and hum.
It sounds like you're describing a circuit beginning at 12V supply, through a 4.7k resistor, and through a 100uF capacitor to ground(?) Then connect a 10k resistor from the above resistor/capacitor junction to the ECM +lead? I probably have this wrong. I see lots of current limiting, but no DC voltage dividing. Thanks for your patience. Your help is much appreciated, here. Rob | ||
| The electret mic operates from a low voltage and draws about 0.5ma. So a 4.7k resistor with a 100uF capacitor is a filter for the supply to the electret mic and the 10k resistor powers it and is its load. Of course the two resistors make a voltage divider.
I've been experimenting with various resistor arrangements today, and taking measurements. What Audioguru suggested does seem to work. The voltage at the + terminal of the mic is reduced to an acceptable level. I was about to go ahead and set up the circuit that way. But I can also drop the voltage to the mic with a voltage divider. Now I don't know what the ramifications of doing it one way or the other are. Is there a "best" way that draws the least amount of power, and holds the voltage at the mic most steady? Thanks | ||
| The 4.7k resistor in my circuit allows the supply to the 10k load resistor to the mic to be filtered. Then the voltage to the mic is divided down to 4.65V (sure there is a voltage divider) which is fine. If you want the mic to produce distortion from loud sounds then increase the 4.7k resistor to 10k so the mic gets only about 2V (sure there is a voltage divider).
| Audioguru, you do seem to know what you're talking about and, as I said, from the bit of experimenting I did, your design seems to do what was needed. It's just that the ECM isn't connected to the resistors in what I've seen described as a "voltage divider," that is, connected between two resistances in series. Hey, whatever works.... No offense intended. Maybe you and Nigel will hash out what is or isn't a voltage divider.... The ECM I was messing around with today is a cheapie that someone gave me. I'm going to go ahead and order a couple of good ones and some other goodies from Digi-Key tomorrow. Thank you, sir. | |
Calling that a 'divider' is just going to completely confuse everyone. | ||
| Dear audioguru: I am trying to power an electret mic from an USB port, i.e. +5V. I am using your circuit and it seems to work properly. Nevertheless I suppose that the resistor values should better be different from the ones that you provided for Ventura, but i do not know how to calculate them. Please, could you help me? Best regards from spain. | |
Ohm's Law calculates the mic's load resistor. The resistor with the lower value is used as part of the filter with the 100uF capacitor so it could be 1k. Then it has 0.3mA x 1k- 0.3V across it and the filtered voltage feeding the other resistor is 5.0V - 0.3V= 4.7V. The mic's load resistor should have half the 4.7V across it which is 2.35V. Then its value is 2.35V/0.3mA= 7.8k which is not a standard value. Use 6.8k. I know Nigel, The resistors do not divide the voltage. Magic divides the voltage.
| Of course the resistors act as a voltage divider, anyone with the slightest knowledge of ohm's law knows that.
| Thank you very much audioguru, but how do you know that the current will be 0.3mA with 2.5V? I have connected the electret MIC directly to the USB port (5V) and I only measure 0.174mA, not 0.5mA. is this measure right? Last edited by jfmateos; 13th April 2008 at 05:17 PM. | |
| Electret mics that I have measured had a current of 0.5mA with 5V across them and a current of 0.3mA with 2.5V across them. Every electret mic draws a slightly different current. Yours is a little lower than most but if it works then it is fine.
| Need help for electret mic preamp | Hyperion1 | Electronic Projects Design/Ideas/Reviews | 34 | 9th December 2008 04:01 PM |
| Sensitive mic questions: electret condenser | Ventura | Electronic Projects Design/Ideas/Reviews | 5 | 4th April 2008 01:26 AM |
| electret mic preamp questions | 3v0 | General Electronics Chat | 23 | 11th January 2008 12:10 AM |
| What appliance class has a plastic enclosure and an earth connection? | Dave#2 | Electronic Projects Design/Ideas/Reviews | 3 | 9th May 2006 09:11 AM |
| Electret Microphone | jdp12345 | General Electronics Chat | 9 | 15th January 2003 05:40 PM |
