Old 9th April 2008, 05:06 PM   (permalink)
Experienced Member
uaefame is infamous around these partsuaefame is infamous around these parts
Cool Transistor
Hello everyone,
I am trying to design a switch using a transistor. I am using transistor because it can handle two current at the same time low and high. I can use microchip to send low signal and transistor open a gate for high current flow. That all my knowledge about transistor.
I want to choose transistor that will do my job?
I have a microcontroller which i will connect to the base which will send 5V signal with 20mA current this will be connect to the base of the transistor.
VCC=27V that mean i use 3X9V battery
VC=23V the device i am using need 23V
Vb=5V from microcontroller
ib=20mA
ic?? not sure about it
R1&R2&transistor not sure about it??
I know that i need NPN transistor
hfe=??
Please tell me how can i select it, if still more information is needed tell me so i can find it out.
uaefame is offline   Reply With Quote
Old 9th April 2008, 05:27 PM   (permalink)
Experienced Member
crutschow is just really nicecrutschow is just really nicecrutschow is just really nice
What is the transistor output connected to and what output signal level do you need? What is the "high current flow" value? The answer to those questions will help determine how to design the circuit.
crutschow is online now   Reply With Quote
Old 9th April 2008, 05:32 PM   (permalink)
Experienced Member
ericgibbs has much to be proud ofericgibbs has much to be proud ofericgibbs has much to be proud ofericgibbs has much to be proud ofericgibbs has much to be proud ofericgibbs has much to be proud ofericgibbs has much to be proud ofericgibbs has much to be proud of
[quote]I want to choose transistor that will do my job?
On load the batteries if they are PP3 will be about 8.4V/battery so, about 25V
Will the 23V device accept 25V.?
ib=20mA
The hfe of a particular transistor is depends upon the collector current.
example: let the collector current be 100mA and the hfe be 50, this would give a minimum base requirement
of 2mA... In order to fully saturate the transistor I would suggest a base current of 5mA.
For R1 the base resistor, assuming a +5v output from the PIC, (5 - 0.7Vbe)/0.005 =860R,, say 820R
If your battery was 27V and the device required 23V, you just cant drop 4V across an emitter resistor as the transistor would not switch correctly with a 5V base drive.
IF you must lose 4volts put a resistor in series with your device.
Example, if Ic thru the device was 100mA, the 4V/0.1 40R, say 39R [use a 1Watt resistor]
hfe=??
Please tell me how can i select it, if still more information is needed tell me so i can find it out.[quote]
Do you follow this.?
Eric
"Good enough is Perfect"
PIC tutorials:
Gramo's: www.digital-diy.net/
Old 9th April 2008, 05:40 PM   (permalink)
Experienced Member
Papabravo is a glorious beacon of lightPapabravo is a glorious beacon of lightPapabravo is a glorious beacon of lightPapabravo is a glorious beacon of light
I don't think the circuit you have shown will be a very good switch. The current through R1 will be equal to the collector current. What ever that current is will depend on the charge on the batteries and the value of R1. As the batteries discharge things will change. You may not be able to keep Vc close to 23V. When the transistor is off Vc will be at Vcc or 27 V, and when it is on it will be at about 4.5V olts
Next I have some doubts that you will be able to source 20 mA into the base of the trasnistor. The emitter will be at 4.3V when the base is at 5V. In this condition the collector will be at Ve + 0.2V or about 4.5V.
I think you need to go back to the drawing board.
Edit: My comments refer to the original circuit, and not Eric's improved version.
We never have time to do it right; but we always have time to do it over.
Papabravo is offline   Reply With Quote
Old 9th April 2008, 05:44 PM   (permalink)
Experienced Member
If you tell us what the device is and what you want it to do.
We could probably advise a better circuit.
Eric
PIC tutorials:
Old 9th April 2008, 07:30 PM   (permalink)
Experienced Member
I have Energy converter III box with 2 sensor connect to it. I want to remove these sensor a replace it with microcontroller. The output of the sensor needs 23V to run the motor if 0V the motor won't run. While repacing the sensor with microcontroller it realize that the microcontroller only provide 5V and the output of the sensor require 23V therefore i came with an idea to use transistor as a switch.
The sensor and the energy converter III information is given in this pdf
http://www.degerenergie.de/downloads...onecter_en.pdf
Old 9th April 2008, 07:58 PM   (permalink)
Experienced Member
blueroomelectronics is a splendid one to beholdblueroomelectronics is a splendid one to beholdblueroomelectronics is a splendid one to beholdblueroomelectronics is a splendid one to beholdblueroomelectronics is a splendid one to beholdblueroomelectronics is a splendid one to beholdblueroomelectronics is a splendid one to behold
Send a message via Skype™ to blueroomelectronics
The DEGERenergie Solar tracking system appears to have some brains, why would you want to replace it?
Bill
Smart Kits build Smart People
Old 9th April 2008, 08:35 PM   (permalink)
Experienced Member
My instructor told me to design an open loop system for the PV solar tracking system. These sensor are closeloop. I am trying to replace it so i can design an openloop system.
Thanks everyone for replying
Old 10th April 2008, 05:15 AM   (permalink)
Experienced Member
That is probably the most misbegotten assignment I ever heard of. The whole point of closed loop systems is to improve performance. I can't imagine why a sane instructor would make a request like this. I'd ask the school for my tuition money back if some clown asked me to do that.
Old 10th April 2008, 05:30 AM   (permalink)
Experienced Member
uaefame is fast becoming the new Walters.
Bill
Old 11th April 2008, 12:47 PM   (permalink)
Experienced Member
The close loop tracking system is so strange. It doesn't track the sun and sometimes it is off by 40degree. Therefore while contacting the company i was asked to do open loop tracking system.
Hesham Ismail Mohammed Sharif
Thank me if you want
Old 11th April 2008, 01:40 PM   (permalink)
Experienced Member
OK, so in the process of trying to get the closed loop system to work the suggestion was made to try an open loop system. It is not clear that you can do this in all cases without rebuilding the system from the ground up.
For example, if the actuator is a DC servo motor with a rotary encoder for position feedback, then there is no practical way to to do this open loop. You can try energising the motor for a fixed time at fixed intervals but ultimately you will have no idea how to make the system perform. I don't know all the details of your system so I can't say weather it will work or not.
It seems to me that if the closed loop system was properly designed then you should be able to identify the problem and improve the situation.
Old 12th April 2008, 12:44 AM   (permalink)
Experienced Member
Back to the main topic open loop, i am a mechanical engineering i am trying to use the old system because its easy i am trying to control it using time I will give it a try.
I gathered all the data from the system now i need to select a transistor so anyone can guide me i am waiting for a reply.
Vc=23V
R1=22ohms
R2=148ohms
hfe=36
P=24W
Vb=5V
ib=0.029A
ic=1.049A
Use my above figure where i first post but change the R2 place to be with the base.
I gathered all data. Now,I only need to select transistor but i am confused how i use these data to select
Thanks in advance
Old 12th April 2008, 02:25 PM   (permalink)
Experienced Member
I guess finding tranistor is hell of a job. I spend 2hours just to find a good website but noting perfect yet.
Is there a website where you input ib or ic or other thing and it sort the transistor. If you know a transistor that is close to what i am looking i am looking forward to know its name. If you know a good website that helps too.
Old 12th April 2008, 03:42 PM   (permalink)
Super Moderator
More a question of no body understands what you're trying to do, your diagram makes no sense, and your random lists of specifications and values doesn't either.
Transistor Biasing UTMonkey General Electronics Chat 16 14th November 2007 07:10 PM
biasing npn transistor without a resistor fvnktion Electronic Projects Design/Ideas/Reviews 30 4th December 2006 10:14 PM
Discrete Pulse width Modulator... Rajagopal87 General Electronics Chat 8 16th August 2006 05:25 AM
Transistor Operation ElectroMaster Electronic Theory 1 23rd June 2006 04:26 PM
transistor amplifier frequency mstechca Electronic Projects Design/Ideas/Reviews 1 9th June 2003 07:47 PM
