| How can I sense induced voltage by wrapping a wire around the spark plug cable of a petrol engine. I have a a car alarm system that can remotely start my car. It came with a device that has a wire that you wrap around the spark plug cable to tell the electronics that the car has started. This system is sealed up by the manufacturer so I can't access the cct. I need an output that I can amplify to drive a 12V relay. Anyone with an idea? Thanks | |
| A couple of turns of 1 mm˛ wire around one of the sparkplug leads will work fine. Leave one end open and the other end goes to your BC547. Bring that to the base of a BC 547. fit a base resistor 47k. and a protection diode + resistor to negative to protect your base from overvoltage. A bit of trial and error may be needed, see what works best. Than amplify signal to whatever circuit you want to drive. I used it to drive a LED and a pulsecounter in my old Ford Falcon.
__________________ There are more ways to get to Rome. Electricity, Electric clocks, Meters and Trains are great. | |
| Thanks, I'll try that now and keep you posted | |
