+ Reply to Thread
Results 1 to 4 of 4
Thread: Lm2917
  1. #1
    iz3dmq Newbie
    Join Date
    Apr 2008
    Posts
    2
    Default Lm2917
    Hello to everyone.
    sorry if i'm opening another post about LM2917; sorry again,I'm Luca From Verona , north Italy , i asking if someone can halp me to convert my anemometer with magnet and reed contact , with an easy LM2917/14 pin.
    i've found something here but only for AC waves and LM2917/8.
    i have some LM2907/8 too,...
    please if anyone can help me with a picture of schematic diagram.
    bye and hello to everyone
  2. #2
    Norlin Good Norlin Good Norlin Good
    Join Date
    May 2007
    Location
    Lawrenceville, NJ
    Posts
    148
    http://www.national.com/mpf/LM/LM2917.html
    has a picture for something that might be useful, didn't look too closely, so you'll have to decide for yourself
  3. #3
    iz3dmq Newbie
    Join Date
    Apr 2008
    Posts
    2
    Hello and tks for your reply.
    i'm trying to see it not too closed , but i have a 14 pin and i don't know like i can connect the others.
    than , i see a magnetic pickup that probably gives an AC not from zero reference.
    i have a reed contact , i could connect a resistor to the power of 5 Vcc and the other side to the ground , than pick up the contacts from the reed.
    do you think that i'm doing a good job? or it s better use another resistor from the ground the the second terminal of my reed?
    bye and tks
    so long
  4. #4
    RODALCO Newbie
    Join Date
    May 2006
    Location
    Akld, New Zealand
    Posts
    937
    Hi Luca,
    From a different angle and perhaps easier to build is to get hold of an old VCR , photocopier or printer, light running steppermotor, and attach it to the anemometer propellor, and drive an electronic speedo from a car with it.
    You get impulses directly proportional with the windspeed.
    I have an old Holden speedo cluster which works of 12 Volts. An extra pin at the speedo requires a pulsetrain which you might be able to collect from the steppermotor, and directly read the windspeed in km/h. As extra bonus is that you get actual kilometres recorded as well on the odometer.
    You may need to use a schmitt trigger to clean up your pulses and a 4017 to get the pulsecount correct.
    This example is an idea I have already for quite a while but haven't had the time to implement it yet.
    I know that the speedo works very precisely when the steppermotor is turned around by hand.
    Regards and good luck with the project ,
    Raymond
    Please don't sent me private messages, I will not answer them.
    The questions asked can be discussed in the open forums.
    http://www.youtube.com/user/RODALCO2007 some interesting electrical stuff to watch.
+ Reply to Thread
  1. help on LM2917
    By kokhc in forum Electronic Projects Design/Ideas/Reviews
    Latest: 5th March 2008, 02:51 AM
  2. Cant get LM2917 working
    By vuchris in forum Electronic Projects Design/Ideas/Reviews
    Latest: 27th August 2007, 08:58 PM
  3. Multisim National Semi LM2917 component
    By Russ_T in forum General Electronics Chat
    Latest: 10th August 2007, 05:06 PM
  4. Help with LM2917 Frequency to Voltage Converter
    By crice in forum Electronic Projects Design/Ideas/Reviews
    Latest: 14th August 2006, 07:31 PM
  5. Need to log the speed of a racecar. Lm2907 or lm2917?
    By AustinT in forum Electronic Projects Design/Ideas/Reviews
    Latest: 27th November 2003, 08:02 AM
Tags for this Thread
