The nickle-titanium alloy probably has the best properties. One use is for frames for glasses that don't easily take a set. Another is in small actuator for model airplanes. John | ||
| yeah, i had read through that first, but i couldn't see how it might apply, so i thought there must be something else about it ... But now i think that it won't do quite what you think it does. Unless ive got it wrong. Which wouldn't be the first time. It seems that if it gets distorted, its supposed to return to its intended shape by heating it up a bit. I don't think it can be made to bend and un-bend, by repeatedly heating and cooling. However, the notion of using heat is a good one, a length of wire could be used in that way, to move mechanical pixels. That need not be very expensive per pixel. It probably wouldn't be very fast either. But good enough for an interesting display. John
__________________ ************************************************** *************** | |
| It is not as fast as a servo in the applications I have read about, but it is sufficiently fast for control of indoor model airplanes. The advantage I see is that you could use a grid and get heat at the X-Y intersections. It would seem to be a lot easier to build a 25X25 grid than connect up 625 servos. John | |
| I'm curious what sort of mechanical device would move something at a X-Y intersection of muscle wire. It's also far too slow for a matrix with real time updates like the wooden mirror. | |
| Hi, JPANHALT: I've been reading up a bit on these "memory wires", and you are correct, they can be made to 'bend and un-bend" repeatedly by heating and cooling. And yes, they are used as actuators in some model aircraft. So they could possibly be used in a similar way to operate a wooden pixel as part of an array. BLUEROOMELECTRONICS: Yes, it would be a bit slow but if the movement required was short then it could be fast enough to produce interesting results. As to the intersection ... Quote:
that would be ordinary wire, the "muscle wire" would be fed from the intersections. The wooden 'pixels' would just be pivoted on pins, and they would take very little effort to change angle, the actuator could be positioned so that a small movement caused a significant change of angle of the 'pixel'. A lot of trouble to make an array of even 100 X 100, but i would think possible. Regards, John
__________________ ************************************************** *************** | ||
One would need to know more about the physical design to go further on the muscle wire design. Flipping parallel to the X or Y axes would yield something similar to the original work d'art and the project as described by the OP. Perhaps, just to be contrary, one could rotate on the perpendicular (Z) axis. That could lead to a different mechanical arrangement, and I think it might even present a more interesting effect to the observer. John John | ||
| Mechanical Design | watzmann | Robotics Chat | 9 | 9th November 2007 02:28 AM |
| 16F628 delay bug/quirk | Tableleg | Micro Controllers | 4 | 29th August 2007 01:47 AM |
| Drapery motor AC120V - mechanical limit switch convert to current sense | pico | Electronic Projects Design/Ideas/Reviews | 4 | 2nd November 2006 01:57 AM |
| Help with fabrication and design of mechanical parts | mayhem | Robotics Chat | 7 | 9th March 2006 05:52 PM |
| Will current Mirror circuit deliver constant current to LED? | Haru | General Electronics Chat | 10 | 14th April 2005 11:07 AM |
