+ Reply to Thread
Results 1 to 14 of 14
Thread: Speaker
  1. #1
    uaefame Newbie
    Join Date
    Feb 2008
    Location
    Dubai, UAE
    Posts
    270
    Cool Speaker
    Hello there, I want to do a project where i can control the frequency of the speaker. I want to know how can i control frequency of the speaker.
    For example apply a certain voltage to control different freqency?
    Can some one give me a clue about it? or a website that explain it?
  2. #2
    Norlin Good Norlin Good Norlin Good
    Join Date
    May 2007
    Location
    Lawrenceville, NJ
    Posts
    148
    Try this:
    Adjust R2 to adjust the frequency
  3. #3
    uaefame Newbie
    Join Date
    Feb 2008
    Location
    Dubai, UAE
    Posts
    270
    Thanks norlin,
    I wanted to control the frequency of the speaker. In simple words, i wanted to control the viberation. I know your diagram is for tone, i wanted viberation.
    8ohms speaker i began understanding how speaker can be classified.
    Thanks in advance
  4. #4
    crutschow Excellent crutschow Excellent crutschow Excellent crutschow Excellent crutschow Excellent crutschow Excellent
    Join Date
    Mar 2008
    Location
    USA
    Posts
    3,009
    All vibrations have frequencies associated with them which are tones. By vibration are you meaning a low frequency tone? If so, what frequency?
  5. #5
    Abeer_engjbr Bad
    Join Date
    Oct 2007
    Location
    Jordan
    Posts
    75
    You can use an RC circuit in parallel and change R , or you may use a crystal osclliator as far as I know.
  6. #6
    uaefame Newbie
    Join Date
    Feb 2008
    Location
    Dubai, UAE
    Posts
    270
    Yes indeed i am trying to use low frequency for my application something around 11Hz - 1kHz. I want to visualize the viberation. If you know about a circuit that will work please guide me. I am looking forward for an answer.
  7. #7
    Join Date
    Nov 2003
    Location
    Derbyshire, UK
    Posts
    29,788
    Quote Originally Posted by uaefame
    The circuit above will do what you want, alter the value of the timing capacitor to get the range you require.
  8. #8
    uaefame Newbie
    Join Date
    Feb 2008
    Location
    Dubai, UAE
    Posts
    270
    I will give it a try Btw, what value of capacitor you suggest.
    For Q1 B2 is the .....(collector)??? B1 is the ....(emitter or base) ??? E is the ...(emitter)?? can you point this out please and what type of transistor if its a transistor?
    Thanks in advance
  9. #9
    Join Date
    Mar 2008
    Location
    USA
    Posts
    3,009
    The oscillator circuit posted by Norlin is not a sinewave oscillator. It uses a unijunction transistor as a relaxation oscillation whose output is a series of pulses. Thus the sound will have many harmonics as well as the fundamental frequency.
    A unijunction transistor is an old device type specifically designed for oscillators. B1 and B2 look like about a 6k ohm resistor between the terminals. As C1 charges through R1-R2, the voltage on E rises until it reaches the transistor standoff voltage (typically about 70% of the voltage between B1 and B2) at which time E suddenly changes from a high impedance to a low impedance and discharges the charge on C1 through B2. After C1 is discharged, E goes back to the high impedance state and the process repeats.
    If you prefer a purer sinewave it can be generated with a function generator IC such as the Intersil ICL8038.
    Microprocessors with a pulse-width-modulated (PWM) output could also be programmed to generate a low frequency sinewave.
  10. #10
    rjvh Excellent rjvh Excellent rjvh Excellent rjvh Excellent rjvh Excellent
    Join Date
    Dec 2007
    Location
    cambodia
    Posts
    865
    your frequency range should be lower if you want to folow it with you eyes
    (1Hz to 20Hz)
    the frequencys you talk about is posible to see with a trill plate and sand on it but folowing the speaker with your eyes is imposible at frequencys higher than 25 Hz
    Robert-Jan
  11. #11
    Join Date
    Mar 2004
    Location
    Canada, of course!
    Posts
    19,842
    A strobe light will allow a speaker to be seen at nearly any frequency.
  12. #12
    Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent
    Join Date
    Apr 2006
    Location
    England
    Posts
    13,076
    Good luck getting hold of a unijunction transistor.
    The simplest oscilator circuit is the reverse bias oscillator. You can change the frequency by varying the capacitor and resistor values.
    http://www.geocities.com/CapeCanaver...s.html#REVERSE
    if I know the answer.
  13. #13
    uaefame Newbie
    Join Date
    Feb 2008
    Location
    Dubai, UAE
    Posts
    270
    I am interested to know how can i generated sinwave using microchip 16F84, If its possible guide me. Becasue the input to the 4ohms speaker that i will buy is AC therefore i am interested in know how can i do generate sin wave using 16F84.
    Thanks in advance
    Hesham Ismail Mohammed Sharif
    Thank me if you want
  14. #14
    Join Date
    Apr 2006
    Location
    England
    Posts
    13,076
+ Reply to Thread
  1. speaker phase tester for audio installer
    By r10069 in forum Electronic Projects Design/Ideas/Reviews
    Latest: 13th January 2009, 04:32 PM
  2. Help converting speaker phone to line level
    By jeffbearer in forum Electronic Projects Design/Ideas/Reviews
    Latest: 24th November 2007, 07:39 PM
  3. Power a subwoofer from a remote speaker.
    By mramos1 in forum Electronic Projects Design/Ideas/Reviews
    Latest: 19th November 2006, 08:24 PM
  4. Speaker Vs Microphone
    By ghauri in forum Electronic Projects Design/Ideas/Reviews
    Latest: 24th December 2005, 05:20 PM
  5. help fix old audio toy (headphone speaker)
    By gliptitude in forum General Electronics Chat
    Latest: 1st March 2005, 10:51 PM
Tags for this Thread
