| Hi, I'm looking to boost a signal from ~1V to 5V to trigger a function generator, which will then generate a pulse in burst mode. It's currently not triggering at all because of the low voltage of my input signal, which is a saw tooth waveform, 1V peak to peak, that repeats ~100Hz. Can someone recommend a general purpose op amp for this purpose? I plan to build something similar from this site: http://webpages.ursinus.edu/lriley/r...its/node5.html Thanks, Michael | |
What supply voltage do you have available? Any general-purpose op-amp should easily be able to handle your job. I've got a whole whack of ancient LM358s and I'd be tempted to use one of those if I was building this thing, just to try to use one up. And it'd only use half of it. Or maybe an old 741 or something. Normally I don't think anybody would recommend these old beasts for anything anymore but they should have no problem with your job. If you want better op-amps for about the same price you could try a TL071 or TL081. Good luck, Torben | ||
| I am thinking about powering it from a 12V AC adapter. I think all of these op amps require a +/-ve voltage supply. Is there a model, or do you know any circuit setup that I can use that needs only one power supply for my application? Thank you for the suggestions. You can tell I'm not too familiar with circuits. I guess I kind of want something that just works. Michael | |
| Any opamp will operate from a single polarity supply if you bias its inputs correctly. A few opamps have an input and an output that still work at the negative supply voltage which is 0V if there is only one supply.
| Hi Michael, Check the sticky message Dual or single supplies for opamps in General Electronics Chat. Audioguru made a diagram showing how to connect op-amps for either dual or single supplies. If you have any questions ask away. It's also been covered a few times already so searching the forums should turn up some existing explanations. Good luck, Torben | |
| Thanks, I will search more carefully next time. I think with the given single supply circuit, the output voltage from 0V would be 6V? (Correct me if I'm wrong) Since I want the output to vary between 0 and 5V, maybe I do need a -ve supply. Would this chip work? http://www.electronicsinfoline.com/C...pply/7018.html It seems like a simple solution. Thanks, Michael | |
| hi Michael, Since your function gen dosn't 'see' the 1v saw tooth tigger, a simple single supply opa would do fine. If you power say a LM358 from +6V, the output will limit at about +0.5V thru +5V anyway. As Torben suggests, at 100Hz, a LM358 is an inexpensive choice. A point to measure, is the driving sawtooth referenced to ground.? That is, does it swing +/- about the 0V line or is it referenced above 0v.? What form does the FG trigger input expect, eg: fast edge or will it accept a slow sawtooth.? Is it important on which part of the sawtooth the FG triggers.? The reason I am asking so many damn questions, you may require a comparator that generates a 'edge or gating pulse' to the FG, rather than an amplified saw tooth. Hope you follow this..
__________________ Eric "Good enough is Perfect" PIC tutorials: Gramo's: www.digital-diy.net/ Bill's: www.blueroomelectronics.com/ | |
| Appreciate all the advices. I got the triggering working with a simple voltage regulator (LM311) after reading more about it. With a POT, there's the added advantage of this setup for setting where during the sawtooth I would like the trigger to happen. Thanks, Michael | |
For future reference a LM311 is a Comparator, not a Voltage regulator.
| Simple DJ BPM Counter | derrickr | Electronic Projects Design/Ideas/Reviews | 9 | 18th August 2008 09:19 AM |
| Clamp output of op amp | dazza000 | Electronic Projects Design/Ideas/Reviews | 21 | 9th November 2007 09:32 AM |
| Simple Robot From Scratch Parts? | GreenAce92 | Robotics Chat | 7 | 28th October 2007 12:42 AM |
| little help with my program please - simple count loop | kud0s | Micro Controllers | 5 | 7th July 2005 10:40 PM |
| simple help.. Making a simple amplifier. pls help urgent. | paulbostaph | General Electronics Chat | 19 | 20th May 2003 05:32 PM |
