Old 7th April 2008, 03:34 PM   (permalink)
Default Simple driver circuit doesn't work
I'm designing a kind of light sequencer, in which a 4017 counter should light up incandescent bulbs (one at a time). It works, but the bulbs glow very faintly. I guess it has something to do with the driver circuit shown below.
The transistor is a small signal BC547B (max Vce=45V, max Ic=100mA, hfe=200).
When the 4017 output is 12V, V_Bulb is only about 11V.
It's a simple circuit, so it should work, I think...
Any ideas? Would it help to have a resistance between the base and the 4017 output?
/Christian
Chrisbo is offline
Old 7th April 2008, 04:25 PM   (permalink)
/Christian
You picture posting is at fault.. can't see it..
Eric
"Good enough is Perfect"
PIC tutorials:
Gramo's: www.digital-diy.net/
ericgibbs is online now
Old 7th April 2008, 06:47 PM   (permalink)
Ok, I'll try again...
Hope this is visible
/Christian
Chrisbo is offline
Old 7th April 2008, 06:52 PM   (permalink)
/Christian
hi Christian,
1. Open a REPLY window, scroll down till you see a Manage Attachments button, left click.
2. Click Browse on the new window, this open your PC files, select your image file.
3. Click Upload, wait till its done [ref progress bar on window]
4. When its done close this window
5. Make sure your file type is accepatable
Try again..
Eric
PIC tutorials:
Old 8th April 2008, 12:03 AM   (permalink)
How much current does the bulb take?
crutschow is offline
Old 8th April 2008, 12:16 AM   (permalink)
12V bulbs do exist but they are kinda specialized.
If you're trying to light a 120VAC or 240VAC bulb you're going to be SOL.
I didn't notice if you filled in your location.
We never have time to do it right; but we always have time to do it over.
Papabravo is offline
Old 8th April 2008, 02:58 AM   (permalink)
Why doesn't he attach the schematic here so we can see it instead of trying to post it over there where it doesn't work?
audioguru is offline
Old 11th April 2008, 11:25 PM   (permalink)
12V is a pretty common voltage.
11V looks like what you'd expect from an emitter follower when you take into account the saturation losses.
Your tiny transistor is wasting a huge amount of power and will burn up very quickly.
Screen name: Aloone_Jonez
Hero999 is offline
Old 12th April 2008, 02:42 AM   (permalink)
/Christian
This circuit won't work as the base has to higher than the emitter. You would be better off connecting the lamp from the collector to +24V, grounding the emitter and connecting a resistor between the base and the output of the 4017
k7elp60 is offline
Simple thermostat circuit to control seed propagator Jules Electronic Projects Design/Ideas/Reviews 4 3rd April 2008 04:20 PM
Battery charger cum active circuit driver yagtoby Electronic Projects Design/Ideas/Reviews 0 27th September 2006 03:41 PM
Will this circuit work? beluluk Electronic Projects Design/Ideas/Reviews 5 23rd July 2006 05:31 AM
Would anyone mind simulating this simple circuit for me? William At MyBlueRoom Electronic Projects Design/Ideas/Reviews 16 8th April 2006 09:02 PM
New to electronics... building a simple circuit. drawagoat Electronic Projects Design/Ideas/Reviews 19 2nd May 2005 12:22 AM
