| Hey guys, im from australia and am trying to build an american guitar amp anyway i have a problem with the transformer and just needed to know two things. one is that my local store sells a good transformer that gives pretty decent compatibility with the circuit in terms of voltage, it takes the 240 volt aus power. the two bottom taps are 15v and i need a 5v and a 6.3v for these, so how would i calculate the right resistors for these taps to connect to, to bring the voltage down to the right value? secondly, would it be easy for a noob like myself to wire up a transformer myself? im trying to save a little money and get the voltages closer. | |
| It looks that you have a valve amplifier with 6.3 volts ac for the heaters. Normally they are fed from a dedicated 6.3 Volts ac winding of the TX. You can use a 5 Volts regulator (7805 or 7805 + 2 diodes in series on the negative to get 6.2 volts, for the valves, or an LM 317 and set it for 5 volts or 6.3 volts but it would be very inefficient. E.G. 1 Amp at 15 - 6.3 Volts 8.7 volts = 8.7 watts dissipated in heat. It is better to have for the valves a dedicated 6.3 volts ac winding. Also a transformer gives ac which you will need to rectify to dc via a bridge rectifier, and filter capacitor.
__________________ There are more ways to get to Rome. Electricity, Electric clocks, Meters and Trains are great. | |
Assuming the rest of the transformer is OK?, then simply use a separate heater transformer for the 6.3V. | ||
| Where do you need 5 volts for in a valve amplifier ? I was pondering about that one over the last hour. Normally 6.3 volts for the heaters and a HV winding (± 200 Volts ac) for your HV dc to supply the 350 V dc for the valves. Regards from across the ditch, Raymond
| JJ Just in case you have not yet made up your mind look at http://www.drtube.com/guitamp.htm. They have lots of little guitar amps schematics (mainly from the 60's 3 and 4 valve jobs. Some very simple and also some very sophisticated ones Also http://www.vintage-radio.net/ is a very helpful website when it comes to valve type amps, if you are having problems. Cheers RH | |
| Transformer Question | firealarmfreak | Electronic Projects Design/Ideas/Reviews | 5 | 3rd March 2008 02:40 PM |
| Transformer Problems? | MsStateDawg | Electronic Projects Design/Ideas/Reviews | 15 | 2nd November 2007 11:17 PM |
| Problems selecting a PCB Transformer | NewcastleSAR | Datasheet/Parts Requests | 31 | 4th January 2007 08:16 PM |
| Differential transformer how to measure this signal | sardineta | Electronic Projects Design/Ideas/Reviews | 18 | 7th October 2004 03:31 PM |
| help with stepdown transformer | cmer | Electronic Projects Design/Ideas/Reviews | 3 | 6th June 2004 04:24 AM |
