Old 6th April 2008, 11:23 PM   (permalink)
Default How to build a Shocking Device
It needs to be run on a 9 volt Battery and I am a newb and I could use easy instructions.
Ummm It is going to be turned on by a switch and it needs to be small, fitting inside an easy button cap, the size of a AA Battry
any ideas?
Mr.StevenFeldman is offline
Old 6th April 2008, 11:34 PM   (permalink)
This question gets asked nearly every month.
http://www.electro-tech-online.com/e...light=stun+gun
Screen name: Aloone_Jonez
Hero999 is offline
Old 6th April 2008, 11:59 PM   (permalink)
I don't want a stun gun, just a joke that doesnot hurt but scares the crap out of some one.
Old 7th April 2008, 08:40 PM   (permalink)
Just tell the person you want to scare what the price of gas is these days, that'll scare 'em.
Actually there are kits for small hand zappers on the net.
http://www.positiveoffset.com/
http://www.ryanmcginty.com/orgone/zapperinfo.pdf
http://curezone.com/forums/am.asp?i=654706
iONic is offline
Old 7th April 2008, 08:53 PM   (permalink)
Use a camera flash board, without a load and with 2AA batteries, it can generate 1000V+ for a few seconds.
Krumlink is offline
Old 7th April 2008, 10:41 PM   (permalink)
Unless you change the cap value in those disposable camera flash boards you may face liability charges for the potential they could cause to some unsuspecting person. I have had may shocks from them and they pack a real punch, far too much for fun and games.
If I had to choose between the camera flash shock and the 120VAC wall outlet I would find it hard to do except for the fact that I know the wall outlet had the greater potential for injury.
iONic is offline
Old 8th April 2008, 12:18 AM   (permalink)
You really need to find a more productive outlet for your energies.
We never have time to do it right; but we always have time to do it over.
Papabravo is offline
Old 8th April 2008, 02:37 AM   (permalink)
just connect a relay in series with a PBNO switch and a 9 volt battery.
Connect negative to common (on relay), Connect common to ignition coil and ground the other side of the ignition coil.
Place a wire leading to ground near (not touching) the HV output, this is your spark gap, placing an object in between the two connections will cause the object to conduct the HV and therefore cause a shock.
Its quite fun...............................to watch
Below is a schematic just showing the battery relay and ignition coil, you have to place the button in yourself just in series. (in the diagram a condenser/capacitor is also connected in paraell this limits the amount of sparks in the relay and expands your projects run-time i recommend installing the capacitor)
http://www.electro-tech-online.com/a...chmentid=18367
Hope this helps Jordan
spitso is offline
Help on project - building a wireless controlling device Albert Smit Electronic Projects Design/Ideas/Reviews 2 19th March 2008 07:18 PM
Need help with accumulator measuring device Crlsn Electronic Projects Design/Ideas/Reviews 2 29th February 2008 10:19 AM
Unknown device type - CCS compiler i2c2k Micro Controllers 3 2nd August 2004 10:38 PM
Looking to hire someone to design a radio device. yukz71 Electronic Projects Design/Ideas/Reviews 14 1st July 2004 07:06 AM
[b]Power supply to a sensitive measuring device[/b] min_anna Electronic Projects Design/Ideas/Reviews 1 13th April 2004 11:59 AM
