| Hi my proect is to control 2 device wireless.. what would initial output of 4 data lines in the circuit below?.. I want to use 2 data lines D1 & D2( to ground using 2 pushbuttons).. for to control 2 diff. 12v relays. Using which transistor can i drive 12v relay from 5v?.. which is the best solution for my task.. thanks.. | |
| Do you know the coil current or coil resistance for the 12v relays?...this will help choosing the right transistor. Ken
__________________ "To invent, you need a good imagination and a pile of junk." Thomas A. Edison (1847 - 1931) | |
| Small current relay.. | |
| A 2N3904 with a 2.2KΩ base resistor in a common-emitter confiduration should work. Add a diode (1N4001 or equiv.) across the coil with the cathode to +12v and the anode to the transistor's collector. HI out = relay ON. Ken
| Wireless network - help | whiz115 | General Electronics Chat | 5 | 13th December 2007 05:23 AM |
| HT12D Connecting problems | azrael_LW | Electronic Projects Design/Ideas/Reviews | 0 | 10th September 2006 11:18 AM |
| Optimizing wireless doorchime circuit range | Futterama | Electronic Projects Design/Ideas/Reviews | 13 | 11th September 2005 05:04 PM |
| Wireless Alarm- 48 tramsmitters, 1 reciever. microcontroler? | agwill | Micro Controllers | 6 | 10th January 2005 06:47 AM |
| Controlling robot from PC, using wireless LAN and USB camera | keops_777 | Robotics Chat | 10 | 2nd September 2004 07:30 PM |
