+ Reply to Thread
Results 1 to 11 of 11
Thread: Drive 2N7000 direct from 4071 CMOS OR
  1. #1
    dannix Newbie
    Join Date
    Jul 2007
    Location
    UK, Doncaster
    Posts
    92
    Default Drive 2N7000 direct from 4071 CMOS OR
    I am wondering if the attached will work before I get the parts in. Would appreciate it if one of you fine experts cast an eye of the attached schematic.
    I am wanting to turn on 4 fans if one logic input is high, thus the DP switch or turn any fan on seperatly via the associated switches using the other OR input, the output drives a 2N7000 mosfet to switch the fans on.
    Thanks in advance!
  2. #2
    on1aag Good on1aag Good on1aag Good
    Join Date
    Aug 2006
    Posts
    512
    Hi Dannix,
    You forgot to add pull-down resistors on the inputs of the 4071's,
    use 5 x 100k or so. You also forgot to connect diodes across the
    motor terminals. The presence of R1 is not clear to me, it's not
    needed.
    on1aag.
  3. #3
    dannix Newbie
    Join Date
    Jul 2007
    Location
    UK, Doncaster
    Posts
    92
    Hi, R1 was me playing with pull up/down resistors in a simulation. I did not have any diodes as the fans are brushless with internal protection. But I may add them just in case they get changed in the future.
    So I need 100K pull down on the inputs? what is the purpose of this?
    Forgive me I am still learning. I read that I should add a ferrite bead before the 2N7000 gate, I dont want to do rappid switching, so I guess these are not required.
  4. #4
    mvs sarma Excellent mvs sarma Excellent mvs sarma Excellent mvs sarma Excellent mvs sarma Excellent mvs sarma Excellent mvs sarma Excellent mvs sarma Excellent mvs sarma Excellent
    Join Date
    Oct 2006
    Location
    Hyderabad, India.
    Posts
    2,475
    Blog Entries
    1
    I wonder, even with brushless motors whether we need the Back emf protection diodes. After all the mosfet is switching OFF the current thro the motor. even then back emf is generated and the mosfet
    Regards,
    Sarma.
  5. #5
    Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent
    Join Date
    Apr 2006
    Location
    England
    Posts
    13,035
    How much current do the fans draw?
    The 2N7000 is only good for 200mA.
    You're better off with BJTs for small loads like this, a 2N2222A would do the job.
    if I know the answer.
  6. #6
    dannix Newbie
    Join Date
    Jul 2007
    Location
    UK, Doncaster
    Posts
    92
    are these the changes you you mean?
  7. #7
    dannix Newbie
    Join Date
    Jul 2007
    Location
    UK, Doncaster
    Posts
    92
    Hi, I have added the back emf diodes anyway. The fans are 160mA each, I have 2N7000's already so unless there is a reason I should not use them I will stick with them.
    I would have done this on bread brd 1st, but I only have one OR gate IC left and really wanted to be sure there was no obvious mistake.
    Can anyone explain the need for the pulldown resistors on the inputs?
    Thanks everyone, most appreciated!
  8. #8
    dannix Newbie
    Join Date
    Jul 2007
    Location
    UK, Doncaster
    Posts
    92
    hold on, is it so the input is not floating when the switch is off? to prevent the IC going nuts from some outside infulance?
  9. #9
    Join Date
    Apr 2006
    Location
    England
    Posts
    13,035
    As you said you don't need back EMF protection on brushless motors with built in drivers.
    The pull down resistors prevent the gate inputs floating and picking up noise which would give unexpected results.
  10. #10
    dannix Newbie
    Join Date
    Jul 2007
    Location
    UK, Doncaster
    Posts
    92
    Ok, thanks for you help guys! I am going to build this on breadbrd tonight (time permitting) and will let you know how it goes tomorrow.
    Thanks again
  11. #11
    dannix Newbie
    Join Date
    Jul 2007
    Location
    UK, Doncaster
    Posts
    92
    Hi, did a quick test and it works a treat! thanks so much for all your help.
+ Reply to Thread
  1. Direct Gate Drive with PIC
    By dknguyen in forum Robotics Chat
    Latest: 17th March 2008, 09:50 PM
  2. Logic Family characteristics
    By Styx in forum General Electronics Chat
    Latest: 6th July 2005, 07:01 AM
  3. CMOS fanout drive capabilities and Bus Pull-up resistors
    By Dialtone in forum General Electronics Chat
    Latest: 16th May 2005, 11:38 AM
  4. CMOS can not drive LS input properly
    By atferrari in forum Electronic Projects Design/Ideas/Reviews
    Latest: 30th January 2005, 06:02 PM
  5. electric car drive
    By franklin2 in forum Electronic Projects Design/Ideas/Reviews
    Latest: 18th October 2004, 02:30 PM
Tags for this Thread
