Old 5th April 2008, 07:44 AM   (permalink)
Default Problem with SMPS
A couple of years back, my SMPS was replaced coz my last one stopped working during a power spike. I just opened it and found that only the fuse was blown. Is there anyway I can check whether the SMPS is working after replacing the fuse without connecting it to my PC or to anything else?
Help me enlarge my army, Click Here!
ashfaqueahmadbari is offline
Old 5th April 2008, 11:39 AM   (permalink)
a blown fuse is Symptom for another problem. so it is likely to get the replaced fuse blown again and may be with BANG.
Its what your friend in Your mind, what you in your friends mind
aljamri is offline
Old 5th April 2008, 11:46 AM   (permalink)
well you could plug it in without it being plugged into your laptop after changing the fuse, but as above its prob going to blow. I had the smae issue last week, replaced the fuse and bang, at least it was not plugged into the laptop
dannix is offline
Old 5th April 2008, 01:11 PM   (permalink)
I'm pretty sure it doesn't have any other problem coz it happened during a power spike when my UPS wasn't connencted. could you tell me how i can switch it on after connecting it to the mains?
Old 5th April 2008, 01:30 PM   (permalink)
Do you know how to turn the PS on without connecting it to a computer? If not, go to http://pinouts.ru ; dig down through power to your brand. Dell and ATX are similar, but enough different to cause a problem. There is a PS/on pin on the main connector. In older Dells (2002 or so) is it gray, and pin #13; in ATX, it is green and pin 16. Ground the correct pin and the the supply should turn on. John
jpanhalt is offline
Old 5th April 2008, 03:26 PM   (permalink)
If it is mains powered, mostly the bridge diodes( at least one diode of them, would have failed. before powering ON better check the bridge and the High voltage DC electrolytic cap.
the next culprit could be the MosFET switch, if one is used. otherwise the switcher chip itself.
Ensure that these are not having short circuits to input Dc return and then perhaps you can switch ON, by enabling a loop at some pins(try to see the details on the output connector-- detailed by Jpanhalt.) that the PC simulates, as if the SMPS is working on the PC( assuming it is one used for desktop.).
also check the galvanic cap between output common to input dc return or perhaps neutral.
P S: try this link
http://www.duxcw.com/faq/ps/ps1.htm for power ON info
Regards,
Sarma.
mvs sarma is offline
the link doesn't seem to work, are you sure it's right?
Old 5th April 2008, 03:48 PM   (permalink)
Not necessarily, it could have been a brownout which causes the SMPS to draw more current and blow the fuse, leaving all the other components unharmed.
Screen name: Aloone_Jonez
Hero999 is offline
Old 5th April 2008, 04:03 PM   (permalink)
http://pinouts.ru/Power/dell_atxpower_pinout.shtml
This link is the the Dell plug. You can work backward from it. The pinouts.ru was in my browser history and should have worked. I checked the above and it is working.
John
Edit: The original link seems to be working now. Must have been a short outage.
jpanhalt is offline
Old 5th April 2008, 06:52 PM   (permalink)
Default Hmmmmm...
It seems it ain't that simple to power on my SMPS. Is there a more 15 yr old friendly way to do this which wouldn't require me ripping apart my PC?
Old 5th April 2008, 07:10 PM   (permalink)
First a little information:
1) Do you have a metal paper clip or piece of solid wire that is the right size to fit in one of the connector sockets (about 1 mm to 1.4 mm diameter)?
2) What brand of computer and model do you have? If it is home-built, what is the motherboard?
3) How many pins are in the main connector to the mother board? Are there 2 main connectors (usually 16 pins and 24 pins) or just one main connector (20 or 24 pins) plus a small 4-pin connector?
Since you got the PS out, opened it, and fixed the fuse, I think you will be able to get it started just fine without risking plugging it into your MB. But, I would need that information to tell you which pins need to be shorted together with the wire.
John
jpanhalt is offline
Old 5th April 2008, 07:17 PM   (permalink)
The only 15 year old friendly way is to get it repaired from a local service facility.
It is very risky to handle such power supplies, without proper background, training, testing equipment and precaution. It involves public mains supply and fatal risk.
Regards,
Sarma.
Old 5th April 2008, 07:18 PM   (permalink)
Most ATX power supplies need a load on the 5V before they'll turn on.
Bill
Smart Kits build Smart People
Old 5th April 2008, 08:11 PM   (permalink)
That is not my experience. If you ground the PS_on pin, it will start, but may not give much power until you put a load on them. At least that is my experience with Thermaltake (ATX), Antec (ATX), and Dell (DELL!) supplies.
I think the question is whether the supply will "turn on" and not continually blow the fuse. I don't think shorting between the green (pin 16) and either adjacent black pin is beyond a 15-year old. Some members on this forum are younger than that and are doing some pretty nice things.
It is important that s/he not do that to a Dell (pin 16 is com, and there is no green, so there is minimal risk). The other way around (on the older Dimension series and others, it's pin 13, grey) could end up connecting 3.3V to ground and hurting the PS. Shock risk is low in either case.
John
jpanhalt is offline
Old 6th April 2008, 12:05 AM   (permalink)
Give the health and safety inspector a fit of apoplexy. Get a 100W mains bulb and solder a pair of croc leads to it. When you get a blown fuse connect the bulb across it and switch on. If it lights brightly, then it was going to blow the fuse. It shold flash and then burn dimly. After replacing a switching transistor, this test can be useful. If the bulb lights brightly then it was going to blow the transistor again, and you get another chance to find out why.
spuffock is offline
Designing an SMPS. lord loh. General Electronics Chat 7 23rd November 2005 01:56 PM
Problem; Random pic performance timothyjackson Micro Controllers 7 19th February 2005 07:20 PM
SMPS Problem? mahesh_jo General Electronics Chat 2 1st December 2004 11:45 AM
Big problem!! zezito Electronic Projects Design/Ideas/Reviews 4 29th October 2004 03:05 AM
strange color camera problem schrodingerscat Electronic Projects Design/Ideas/Reviews 5 4th October 2003 08:25 PM
