| Hi guys, I have designed and built the following small signal amplifier for RF application (the tuned circuit is implemented at the collector of 2n2222, the operating frequency is 1MHz), but the output of the amplifier is not satisfactory (but worked well in simulation) as there was only the waveform of negative cycles (the output stayed at 0 V when positive cycles)... Did I provide the wrong bias to the amplifier OR anything? Please help me, any suggestions on the circuitry improvement shall be appreciated, thank you!!! | |
| What are the actual voltages on the transistor? (Nodes 1, 4, and 7) Does the circuit perform better with different signal frequencies? | |
| I'm not sure I understand your simulation. You show input voltage and output voltage in pico volts. That seems wrong. Also, I didn't bother to check your tank circuit calculation for resonant frequency, did you double check? A common emitter circuit as you have shown is hardly an RF amp due to the Miller effect. Although 1 MHz is really low for what I would consider RF these days. Give us some more details.
__________________ "Everything that is done in the world is done by hope." -Martin Luther "There are two ways to live your life. One is as though nothing is a miracle. The other is as though everything is a miracle."-Albert Einstein | |
| lowering impedance on a class D amplifier | amplifierfreak | Electronic Projects Design/Ideas/Reviews | 5 | 27th June 2007 08:56 PM |
| Class D amplifier | kambliarup | General Electronics Chat | 21 | 21st August 2006 03:34 AM |
| Class B amplifier | shoba | General Electronics Chat | 6 | 16th August 2004 04:06 AM |
| Class C RF Amplifier Question | bd13 | Electronic Projects Design/Ideas/Reviews | 3 | 15th November 2003 02:14 AM |
| simple help.. Making a simple amplifier. pls help urgent. | paulbostaph | General Electronics Chat | 19 | 20th May 2003 05:32 PM |
