Im using a 16f877 PIC to drive an LCD screen which will display the frequency of a note played by a guitar - basically a guitar tuner.
I am having trouble with the frequency detection. There are couple ideas that I came up with 1. Run the LM386 output through 74LS14 schmitt trigger (I have already tried this and i have miserably failed at getting output from schmitt trigger). Take output from 74LS14; time the pulse and detect frequency with 16f877. 2. Run the LM386 output through LM2917 frequency-to-voltage converter and use ADC module of 16f877. (Unfortunately, I am not familiar with this IC and have no clue how to convert audible frequencies into voltage; so any input is highly appreciated) Which one is a more accurate method? Is there a better way to capture the frequency? Is there specific way to use 74LS14 that I am not aware of? Any schematics or C and R values to help me with LM2917 available? Thanks in advance, ~transistance |
For a start an LM386 is a really poor choice, it's a power amplifier, you need an opamp.
Next a guitar doesn't output a very pure frequency, so it's not easy to measure like that. EPE did a PIC based one a number of years ago, they used filters controlled by the PIC in order to give a clearer signal to measure - it wasn't a really a trivial project. |
I have seen a similar project where 74LS14 Schmitt Trigger gave out a very clear square wave signals at peak points of the guitar notes. I just connected the gained frequency to an input port and got the output from the corresponding pin. Im wondering if there are additional components used to filter out the signal. Unfortunately the project paper does not specify that part of the circuit.
http://72.211.214.102:3001/senior_pr...finalpaper.doc Last edited by transistance; 3rd April 2008 at 07:34 PM. |
Thans for pointing that out crutschow. I've just been skimming through a lot of papers lately and i missed that. So I see that there is a dual stage LM324 amplifier with low pass filter capacitors. According to the pictures on page 8, this is supposed to give out a clear square wave signal when passed through a schmitt trigger. But i googled the LM324 audio applications and read that the opamp causes heavy crossover distortion. Do you think that LM324 is still gonna be suitable for this project? Can LM741 be a good choice?
I built the dual stage amplifier with low pass filter using TL082. Is it normal to not get an audible output?
I'm using twisted pair wires for my sound input and outputs and still getting a constant 500 Hz noise that the above low pass filter is not filtering out. Could this be because I'm using an adapter to power my protoboard? should i switch to batteries?
But you might try posting your circuit, EXACTLY as you've built it, it's quite possible you've left out many vital components?. |
The very simple circuit has a very simple lowpass filter.
If the guitar is played a little too loudly then its harmonics will trip the Schmitt-trigger, then the output frequency will be wrong. If the guitar is played a little too softly then the Schmitt-trigger will not be triggered, then there will not be an output. Unbalanced audio circuits like this one need shielded audio cables, not twisted pairs that are used for balanced telephones. The schematic of the preamp and lowpsss filter from the little school kids has a few problems.
Uncle $crooge |
is there any suggestions that you got to improve this circuit? how can the low pass be built in a better way?
Check the EPE one I mentioned at the start of this thread, it used variable filters controlled by a PIC.
1. Use a OPA2134 operational amplifier for your low pass filter.
2. Use this 24db/octave low pass filter below filter http://synthius.fileave.com/lowpasfilter.jpg 3. Adjust the crossover point by changing the value of R. 4. Make a preamp before the low pass filter which will allow you to attentuate or amplify the audio signal from the guitar. Therefore, you will be able to detect the frequency correctly no matter how loud or softly you are playing the guitar. |
1. Use a OPA2134 op amp to design your low pass filter.
2. Use the schematic below if you would like. It is a 24/dB low pass filter 3. Change your crossover point by changing the R values. All R values should be the same. 4. Here is the equation. R= 1/(2*pi*1.414*frequency*c) c=100n substitute the desired frequency in the equation to find the resulting R value. ![]() Last edited by synthius; 27th April 2008 at 03:44 AM. |
| Variable capacitor circuits | walters | General Electronics Chat | 83 | 11th March 2008 02:58 PM |
| Audio Frequency Driven LED's (HELP!) | iONic | Electronic Projects Design/Ideas/Reviews | 1 | 29th March 2006 10:42 PM |
| Audio beat detection | jrz126 | Electronic Projects Design/Ideas/Reviews | 21 | 12th May 2005 11:27 AM |
| ADC - Audio Clipping Detection | Noggin | Micro Controllers | 0 | 7th December 2003 01:54 AM |
| Audio frequency signal outputs | Magic | Micro Controllers | 2 | 23rd December 2002 09:28 PM |
