Old 27th April 2008, 02:12 AM   (permalink)
check this out: Peak Frequency detector
http://www.electro-tech-online.com/e...ecuencies.html
synthius is offline   Reply With Quote
Old 27th April 2008, 03:33 AM   (permalink)
If I'm not mistaken you're cascading two sets of S&K with the Q factor of 0.7071 each, so the result will be Bessel response (Q factor of 0.5). So the roll off is not -24 dB/oct (-80 dB /dec) anymore. For 4th order Butterworth filter with -80 dB/dec roll off, it should be designed according to the polynormial:
(s2 + 0.7654s + 1)(s2 + 1.8478s + 1)
(from Wiki)
Superman returns..
bananasiong is offline   Reply With Quote
Old 27th April 2008, 03:42 AM   (permalink)
It is a linkwitz-riley configuration (4th order) which is 24dB/octave/.
Old 27th April 2008, 03:55 AM   (permalink)
Oh I see
I've got to do lots more reading
Superman returns..
Old 27th April 2008, 11:32 AM   (permalink)
The resulting Bessel filter is down -6dB at the cutoff frequency. It eventually reaches 24dB/octave but its cutoff is not sharp.
This type of filter is used in a Linkwitz-Riley speaker crossover network because a highpass and a lowpass add together perfectly (unlike a Butterworth type).
Old 29th April 2008, 01:07 PM   (permalink)
how about this bandpass filter? its supposed to allow 60Hz-340Hz. I was playing around with FilterLab. I am not too experienced with multi-stage filters but i think this is a butterworth filter. The only problem is i can not rebuild the circuit, cause i forgot the attenuation values i used. Nonetheless, i think it should work fine with x10-x20 gain preamp.
Ohh and i noticed that i have to be very precise with R values when building multi-stage filters. Correct observation?
Do you think this filter will solve my problem?
COMMENT ON EPE PIC-A-TUNER:
That is some hardcore assembly, i can not follow where they are actually digitally filtering the non-fundamental frequencies.
NOISE REDUCTION:
I'm planning to wrap all my audio carriers with aluminum wire mesh (mosquito screens - i dunno if thats what its called but you kno what i mean). That should help?
NOTE:
I'm using TL084 for opamps and LM386 for preamp.
Thanks in advance,
transistance
transistance is offline   Reply With Quote
Old 25th June 2008, 02:30 PM   (permalink)
http://www.schickt.de/data/gimmick/t...K_sch_0.73.pdf
Here is the schematic of a what seems to be a fairly nice digital guitar tuner. Unfortunately the project owner only has the .hex file shared, I was wondering what the use of that comparator was? can anyone share some ideas? Could I use this circuit up to only a certain node before the comparator to achieve my fundamental frequency filtering? Or is the comparator there to capture the first fundamental of the polyphony?
Variable capacitor circuits walters General Electronics Chat 83 11th March 2008 02:58 PM
Audio Frequency Driven LED's (HELP!) iONic Electronic Projects Design/Ideas/Reviews 1 29th March 2006 10:42 PM
Audio beat detection jrz126 Electronic Projects Design/Ideas/Reviews 21 12th May 2005 11:27 AM
ADC - Audio Clipping Detection Noggin Micro Controllers 0 7th December 2003 01:54 AM
Audio frequency signal outputs Magic Micro Controllers 2 23rd December 2002 09:28 PM
