| Okay, here's the project. I want to build a lucid dreaming induction device. What it will do is wait 20 minutes after being turned on, then blink two LED's at a rate of about 2 to 3 times per minute. (When placed over your eyelids while you sleep, this is proven to help induce a lucid dream, meaning, a dream in which you realize you are dreaming). Anyway, I need to build this out of cheap, readily available parts. By readily available, I mean, in stock at the local Radio Shack (Don't have Fry's in my part of the country). I know a 555 timer can handle the blinking. I don't know what size capacitors and resistors to hook up to it though, and I don't know how to make it wait 20 minutes before turning on. (Need to be fully asleep and dreaming before the blinking starts). I suppose you could have one 555 operating in monostable mode, (to delay the start of the blinking), which activates a second 555 operating in astable mode (to blink). If there is another way to do this, possibly with fewer components, I would greatly appreciate any suggestions. Remember, this needs to be kept near, or maybe even on the bed while sleeping, so a big clunky circuit board with a dozen components that might get rolled over on is impractical. If you know of any other readily available chips that would work better, to which I wouldn't have to hook as many resistors and capacitors, please let me know. The fewer the better. I know I'm pretty stupid regarding electronics stuff, but me and a lot of other people at dreamviews.com would really appreciate your help. Thanks everybody. | |
| heh, I just watched a show on this the other day, the best of these devices detect when your eyes start REM and then do their blinky thing, 20 minutes is probably just a guideline, though I know when I go to sleep, sometimes it can take up to an hour to fall asleep. | |
| Yeah, the best ones detect REM. We're trying to build a poor man's version. If you wake up after about 5 hours of sleep, stay up for an hour, then go back to bed, you're pretty much guaranteed to begin dreaming right upon falling asleep. So we're not too concerned with REM detection. If we could fiddle with the timing by plugging in a different capacitor, say 9 nF for 20 minutes 6 nF for 30, (or whatever), that would be great, then people could customize it to their own sleep cycle. I know this could probably be done with one single programmable microchip, but that's beyond most of us dreamers. And I don't know, but I think those are expensive and not readily available. We just need to keep it down to as few components as possible while still being buildable by dummies. | |
| hi, Are you planning to sell this device or is it a one off.. If its for trials I would use a laptop, you could get all the time delays you need and also flash the LED's at any rate you choose, using the parallel port. Why do want to lucid dream, there are other self taught methods that can be used while normal dreaming to switch you to lucid.
__________________ Eric "Good enough is Perfect" PIC tutorials: Gramo's: www.digital-diy.net/ Bill's: www.blueroomelectronics.com/ | |
| No, no, these aren't for sale. I'm just putting together a tutorial on how to build your own lucid dreaming mask cheaply and easily. The novadreamer costs over a hundred dollars, which is beyond the reach of many dreamers. We do know of the several techniques for naturally inducing lucid dreams. DILD, DEILD, MILD, WILD, etc, as well as various vitamins that will increase your chanses. What I'm trying to do here is known as EILD, or "Electronically Induced Lucid Dream." Commercial products like the Novadreamer fall into this category. Anyway, your suggestion to use the laptop is great. I have even more questions now. Could you tell me more about it? +What pins in the serial port would I connect the LEDs to? {Edit: I just hunted around Google and found out it's pins 2 through 9, and the ground is like pin 19? I think? Right? Do I need a separate power supply for the LED's? Or will the computer supply the voltage through the parallel port}? +How would I connect them to the pins? {Edit: I just would plug the leads into the holes of the parallel port, correct?} +Should I get a plug-in thing for the parallel port and cut the wire and attach the LED's to that? Is there a special piece of hardware that I would need to get?{Edit: If I would just plug them into the holes of the parallel port, nevermind this one} +How do I go about setting up the timer on the laptop? Do I use the Windows Task Scheduler? +How do I make it output a signal to the parallel port? And how do I make that signal be "blink 2 times a minute?" Do I need some special software? Thanks for the suggestion, this is great. I think most all of us have laptops. If we just knew how to set it up to do this for us. Last edited by unseen wombat; 2nd April 2008 at 08:27 PM. | |
| Not sure if any of this are exactly what you are looking for, but should be easy to adapt. Basically the same principal, different frequency. Haven't look at these projects in any detail, perhaps it is the same thing. Anyway, worth the look. http://www.ullasmann.eu/Alternative.htm | |
| You should checkout Brainwave Generator, and gnaural. They use sound to do the same thing. Brainwave Generator also has outputs specifically for light. You can even vary the rate of flashing over a period of time. It awesome! I have been listening to a custom cycle at night for 3 hours as i sleep. It goes from 12Hz down to 6Hz with peaks into the 14Hz range(representing dram cycles). I have not had a lucid dream yet, but they have all been more magnified and memorable... i am on my way. Keep in touch i would like to find out how this works for you. Nate | |
Hope this covers your questions. By using a laptop for this project, with a little software, it creates a great number of possible enhancements to the concept...
| Okay, here's what I've found. Would this code work for what I want to do, if I removed the user input parts, and if I modified the timer to be 20,000 ms? I'm still not sure how to get it to delay 20 minutes. I found it by doing a google search for "blink LED parallel port." This guy apparently wanted to do something similar. Code: //This example code shows how to switch a LED on/off in Visual C++.
//We use two variables N and L explained below.
//I am assuming you have some knowledge in C++. Instruction to connect the LED is given in the Tutorial.
#include <iostream.h> //The most important include to display data on screen.
#include <conio.h> //Include for outp and inp functions for the printer port.
#include <windows.h> //For _sleep functions for our time delay.
#define addr 0x3BC //IMPORTANT: Normaly 378 is the most common address,
//if not then insert your address instead of 378
int main()
int freq; //Variable for time delay.
int L; //Variable for counts of Blinking LED.
cout<<"\t\t XheavenlyX WELCOMES YOU!!! \n\n"; //How can I forget this ^_^
cout<<"How many times to blink?? Enter 0 to exit: "; //Ask user how many times to blink the LED
cin>>L; //And exit if zero is entered.
if (L==0)
cout<<endl<<"Exiting application..."<<endl; //Code to exit if L = 0.
for (int i=0;i<=5;i++) {_sleep(500);} //A lame pause before exit!
exit(0);
cout<<"Frequency (in mS): "; //Ask user to enter the frequency at which the LED will blink.
cin>>freq; //Store that value in freq.
//Bottom code is the Juice! This will blink your LED the number of times you put in L.
//The speed of blinks will depend on freq. As an example if you entered 500milliseconds. The LED
//will blink twice every second since 500ms is half of 1000ms (1000millisecondss = 1sec)
for (int i=1;i<=L;i++) //The loop. L times to blink.
_outp(addr,1); //Output is high in the first 'Data bit' of port(*), i.e Pin number 2 where you have connected the LED.
_sleep(freq); //freq mS delay between the high and low of LED.
_outp(addr,0); //Output is low now
_sleep(freq); //Pause again between the high,
return 0; //main returns nothing to you. ^_^
} // For an indepth look at
//(*)NOTE: There are some simple calculations to turn on/off the other PINs on the printer port.
//links
// http://msdn2.microsoft.com/en-us/library/733szwah.aspx _outp, _inp etc. And for the 25 way D type connector, is [url=http://www.radioshack.com/search/index.jsp?kwCatId=&kw=25%20d%20connector%20paralle l&origkw=25%20d%20connector%20parallel&sr=1]one of these what you mean? Which would you recommend? | |
| hi, That program fragment is written in 'C' , sorry I dont do 'C', for pC programming, mainly VB5.. Some other member may help you out..
__________________ Eric "Good enough is Perfect" PIC tutorials: Gramo's: www.digital-diy.net/ Bill's: www.blueroomelectronics.com/ Last edited by ericgibbs; 7th July 2008 at 12:23 PM. | |
| Okay, thanks for your help. I don't know VB at all, but I did take C (not ++) like 7 years ago in school. (Of which I've forgotten most). So I solder the wires to pins 2 and 19 on that male 25 pin adapter from radio shack? Is that right? And it's just for convenience in plugging in, correct? It doesn't like, protect the parallel port or anything. I changed a little of the C code to do, I think, what I want. If anyone knows C and can let me know if this will work, I'd appreciate any advice. Code: //This example code shows how to switch a LED on/off in Visual C++.
int main()
int wait; //variable for time to wait before starting blinking.
int length; //Variable for time the LED should remain lit
L=30; //Blink 30 times
wait=1200000; //Wait 20 minutes before starting to blink
freq=20000; //Time to wait between blinks, (in ms)
length=500; //Time to leave the LED on
//The speed of blinks will depend on freq. As an example if you entered 500 milliseconds. The LED
_sleep(wait);
_sleep(length); //Length mS delay between the high and low of LED.
//links
// http://msdn2.microsoft.com/en-us/library/733szwah.aspx _outp, _inp etc. Last edited by unseen wombat; 3rd April 2008 at 07:14 PM. | |
Get some red LED's, use a 220R or 270R resistor in series with the resistor. Connect as per this diagram. You can use insulated twin wire to extend from the 25W D' to the users eye, that is the LED could be mounted on the eye mount.
__________________ Eric "Good enough is Perfect" PIC tutorials: Gramo's: www.digital-diy.net/ Bill's: www.blueroomelectronics.com/ Last edited by ericgibbs; 7th July 2008 at 12:23 PM. | ||
| LDing is awesome, I read this online page a month ago and its really worked well for me: http://www.dreamviews.com/index.php blinks lights are not needed | |
| Hey, I'm a member of the Dreamviews forums. You're right that the lights are not required. There are many other techniques and dietary supplements and even prescription drugs that will enable you to lucid dream. It's not easy though. (For most people, some are naturals). I take Galantamine + Choline on the weekends when I'm able to sleep in. It's actually an OTC Alzheimers medication, but it makes attempting to WILD (wake-induced lucid dream) much easier. Vitamin B6 is helpful too. I also do autosuggestion which is sort of like self-hypnosis while I'm awake, and I wake up and go back to bed almost every day before the time I'm supposed to wake up so that I'm more aware for the final REM periods of the night. The blinking lights are just another aid for when one technique or one supplement gets stale and doesn't work as well anymore. It's always good, I think, to take a break once something stops working. That's why I want to try to make the blinking lights. | |
Using this technique you can 'implant' a trigger word/thought/scene in your mind so when you are dreaming this trigger will make you are aware you a dreaming and then you can switch to lucid. Worked for me.
| Question about Inchworm+ | Quan | Micro Controllers | 54 | 28th October 2007 01:21 AM |
| Need some help with a code provided by ATMEL | ikalogic | Micro Controllers | 1 | 23rd January 2007 03:46 PM |
| Over ocean radio transmitter/receiver device | hybridmetta | Electronic Projects Design/Ideas/Reviews | 25 | 18th August 2005 10:32 AM |
| Unknown device type - CCS compiler | i2c2k | Micro Controllers | 3 | 2nd August 2004 10:38 PM |
| Diff between Slip Ring and Squirrel Cage Induction Motor | avinsinanan | General Electronics Chat | 10 | 23rd February 2004 11:55 PM |
