Ok, I am trying to get good sensitivity for a full 360 degrees. the problem is that the sensors available (x,y) loose their sensitivity and the z axis sensors responds to tilt in both directions. I am using the mma1260 and mma2260 sensors. So what I want to do is mount two x axis sensors perpendicular to each other. The problem is the securing of a small pcb at a right angle to the main pcb. what parts can i use to securely fasten a pcb at a right angle and allow for signals (analog and power) to reach the main pcb? | |
The easy way would be to use epoxy to join the boards. Use wire jumpers to connect the signals and power. You could also use small right angle brackets with threaded holes. Drill the boards to match the brackets and secure with screws. You could used an edge connector socket and plug a PCB into it.
__________________ Please post questions to the forums. PM's are for personal communication. BCHS/3v0's Tutorials Junebug USB PIC programmer kit., USB Bit Whacker, The 15 Minute Printed Circuit Board! (+drill time) | |
| | #3 | |
1. epoxy and jumpers might not last and it would be hard to get the angle consistant from board to board 2. Do you have a recommendation on where to get R/A brackets? 3. I like this the best, can you recommend a 5-8 pin connector that will be secured other than by clip or just friction? | ||
| sensor, tilt |
| Tilt Sensor Project | ironside82 | Electronic Projects Design/Ideas/Reviews | 13 | 29th March 2008 03:46 AM |
| Ideas for a tilt sensor | DannyBoy99 | Electronic Projects Design/Ideas/Reviews | 32 | 24th October 2006 07:42 PM |
| tilt sensor | neel45 | Electronic Projects Design/Ideas/Reviews | 6 | 22nd August 2004 05:25 PM |
| Help with ADXL202 / PIC tilt sensor | Building_A_Robot_Fish | Electronic Projects Design/Ideas/Reviews | 12 | 15th July 2004 02:47 PM |
| tilt sensor | koyeh182 | Electronic Projects Design/Ideas/Reviews | 6 | 4th January 2004 03:23 AM |
