Old 14th October 2003, 12:38 PM   (permalink)
Default BarCode reader
Hi every body,
I wanna a BAR CODE reader project, "directelly by using PC".
I hope you would help me by a detailed-free project or by providing helpfull links.
I wanna this as a project for my study.
Thanks in advance
I walked on the rout of 1000-mile...
when I arrived, I found out I’ve ‎‎walked in the wrong way.
Sherif Welsen is offline
Old 14th October 2003, 07:03 PM   (permalink)
I built a barcode reader at one point using an LED and phototransistor coupled with a 6811 I think. It was the "pen" type that you sweep across the bar code. It then measures the amount of light and dark areas and uses a look up table to translate each set of bars into a particular digit which it then output from its serial port. It worked ok, but not as reliable as the professional versions (though it could read forward or backward). I dont recall what types of codes it could read, but it was not a very difficult project (a few days maybe?).
I bet now it would be even easier. At the time, my micro did not have a prescaler for the input capture, so I had to handle overflow. Now the modern breed (pics/avrs) have the ability to scale the counter so handling overflow is either easier or not even neccessary.
crust is offline
Old 14th October 2003, 11:56 PM   (permalink)
Would you help with the project details please???
Old 15th October 2003, 06:05 AM   (permalink)
Well there are a couple of key questions
(1) What types of codes do you want to examine?
(2) Are you going to use a microcontroller circuit to perform the conversion
I can explain my design as it applies to your situation if you can give us some idea of what your end result is expected to be.
crust is offline
