Old 1st April 2008, 10:41 PM   (permalink)
Default 12 V power supply
Hi everyone, i built a 12 V supply but i need a battery back up included with it. How do I wire that in?
darbdivad is offline
Hi everyone, i built a 12 V power supply but i need a battery back up included with it. How do I wire that in?
Old 2nd April 2008, 12:54 AM   (permalink)
If you can tolerate a 0.7V voltage drop a simple way is to connect each to the load through diodes. You need to have the power supply voltage slightly higher than the battery so the power supply powers the load during normal operation.
If the power supply can tolerate a voltage on its terminals when off and it doesn't draw signficant current, you only need one diode at the battery out.
If you don't want the diode voltage drop then you need a more elaborate switching scheme that can control transistors to switch from one source to the other. For example the intersil ICL7673 is an IC that will switch on the higher of two voltages to the load through PNP transistors.
crutschow is online now
Old 2nd April 2008, 07:44 AM   (permalink)
Depending what its driving, a power diode in the output of the +12V psu and a diode in the battery line is one way.
The junction of the two diode cathodes goto to your circuit regulator.
Eric
"Good enough is Perfect"
PIC tutorials:
Gramo's: www.digital-diy.net/
ericgibbs is offline
Got a new EVBoard How do i supply power to it? cubdh23 Micro Controllers 2 3rd August 2007 10:39 AM
power supply question raphaelriv General Electronics Chat 3 21st May 2007 09:33 PM
Capacitor based power supply dadwhiskers Electronic Projects Design/Ideas/Reviews 6 28th April 2007 09:42 PM
24v DC Power Supply (Help & Information Wanted Urgently) ampthetex Electronic Projects Design/Ideas/Reviews 5 17th November 2006 01:45 PM
Power Supply for a project to be powered within an Auto? hexibot43 General Electronics Chat 16 8th September 2005 03:36 PM
