Old 1st April 2008, 10:41 PM   (permalink)
Default HF multicoupler requesting comments
I recently designed this multicoupler for use on 3 to 30Mhz. It's purpose is to be able to use one antenna and two receivers. I am using the NE5539 as I had some in my personal stock. The NE5539 is used as a gain stage feeding some emitter followers.
My questions are:
1. Do I need a resistor between the output of the NE5539 and the input of the emitter followers to prevent oscillation.
2. Or can I just connect the output of the 5539 directly to the input of the emitter followers.
3. Are the bias resistors for the 2N2222 the right values?
4. Is the output impedance of the emitter followers 51 ohms?
Any and all suggestions welcomed.
Schematic and data sheet of NE5539 attached.
Ned
k7elp60 is offline
Old 1st April 2008, 10:59 PM   (permalink)
First of all, I have to ask the question, "What antenna will you be using?"
If it is anything other than a short wire or loop, I see overload and intermodulation rendering the whole scheme useless.
Feeding a 30 foot long wire antenna into the 5539 will almost certainly result in driving the amp into non-linear operation if it has any gain.
Depending on the antenna, I would just use a resistive splitter.
JimB is offline
Old 5th April 2008, 01:57 AM   (permalink)
Jim, thanks for your reply. I plan to use the coupler between the 50 output of a auto tuned coupler and a pair of receivers. I think the most gain will be 6db.
k7elp60 is offline
Old 5th April 2008, 03:18 AM   (permalink)
You need a bandpass filter at the amplifier input. Use a passive splitter instead of the two transistors:
A better type:
Which is from this page about 1/2 way down:
http://www.w8ji.com/combiner_and_splitters.htm
kchriste is offline
Old 5th April 2008, 10:36 AM   (permalink)
Just one problem with that scheme, an auto tuning ATU requires something to tune with, ie a reasonably large signal from a transmitter.
You dont mention a transmitter.
Auto tune ATUs are no good for receive only applications.
JimB is offline
Site comments killivolt Feedback/Comments 17 24th March 2008 05:40 PM
Revised PIC project Ladybug Pro Comments? William At MyBlueRoom Micro Controllers 14 14th August 2006 05:41 AM
Stamp-like Educational Project, Ideas & Comments welcome William At MyBlueRoom Micro Controllers 4 11th April 2006 09:06 AM
LV Dimmer design, comments... computer Electronic Projects Design/Ideas/Reviews 2 13th March 2005 10:45 AM
Do you think this product is viable? Your comments apprecia Dialtone Electronic Projects Design/Ideas/Reviews 4 20th November 2003 03:29 PM
