Maybe you should google "capacitor ripple current" oh wait, i'll do it for you since you clearly don't understand what i'm talking about: http://www.bhc.co.uk/electric03.htm how about induction heating? maybe you should spend 20 seconds in google and look for how that works. oh even better, i'll spend those 20 seconds for you: http://www.ameritherm.com/aboutinduction.php ... actually only took me 12 seconds. What you're talking about is dielectric heating, a known, but lesser used, heating technique. Information can be found here: http://www.leonardo-energy.org/drupa...t.pdf?download I'm sorry if my imprecise terminology of saying "amps" rather than "ripple current" threw you off. Although ripple current is usually almost always given in amps. Maybe i'll also invent the words "impolite" and "condescending" to characterize individuals such as yourself. | ||
Glyph, you have probably already considered voltage, but just in case you haven't: 1uF has a reactance of 1.3 ohms at 120kHz. At 300 amps RMS, that's 390V RMS, or 560V peak. Keep that in mind when you're choosing capacitors. | ||
| yeah good point. I calculated the ESR of my "big dumb bank" to be about 0.4-0.6 milliohms according to the manufacturer specifications for the individual units. I think the heating is going to be an issue so thats why i wanted to put fan cooled heat sinks on the bus-plate and blow air across the capacitors. Don't know if that will be enough but i won't know until i try. The voltage rating for the capacitors is 3kV. should be enough to handle the working load and (hopefully) handle any unexpected spikes before the overvoltage protection kicks in. heating i think will be my biggest problem. i'm trying to get those specially built capacitors because they got water cooling tubes and other goodies built in to handle it. Although if i can't get it then i'll put on some safety googles, earplugs, and hide behind a wall when i power up my 'big dumb bank'. | |
| Some microwave ovens have a 1uf capacitors rated at 2000v in their klystrons cavity circuit. If that would work then they should not be to hard to get hold of. | |
| Have you thought about immersing them in transformer oil? I found this interesting thread on the topic when searching for "dielectric oil". | |
| | (permalink) | ||
But i've never seen a Klystron capacitor. Although to be honest i've never seen a klystron. I will look into it though, if this fits the bill i'll use that. Would a klystron capacitor operate at far above kilohertz levels? sounds like it would run at gigahertz. Would it still be suitable for a kilohertz induction heater? Quote:
I think the pumping question depends on how much surface area your oil container has, and how much air moves past it. | ||
| I like WIMA polypropylene capacitors. I have used Panasonic polypropylene capacitors. Illinois capacitor are OK. http://www.wima.com/EN/WIMA_MKP_10.pdf If you look at the data sheet for the MKP10 (MKP4, FKP4, FKP1) capacitors and other pulse caps from WIMA you will see graphs of AC voltage and frequency for the capacitors. With a little math you can get from AC voltage and frequency to current. If you are into math, search for more information on dissipation factor and ESR for capacitors. WIMA and Panasonic have application notes for determining maximum current in a capacitor at set frequency. These notes may be slanted for CRT monitor applications where the current flow is a saw wave (for “S” capacitor)(or 20% duty cycle saw tooth for fly-back cap). There are also application notes on using capacitors in resonate power supplies. There are ways of getting from RMS current to heat in a capacitor. In your case the current is sign wave 100% duty so the math will be simple. Most high current capacitors should not be used at their maximum voltage rating when under high current stress. (I know this the hard way) Say you put 100Vp-p @100khz in a capacitor and get 10C rise. The pk voltage is only 50 volts. If you use a 100 volt cap that is only 50% of the rating. If you apply a DC voltage on top of the AC, under low stress applications the AC+DC peak could safely get to 100 volts. Under high stress application the PK voltage should be de-rated some. WIMA seem to have this problem more than Panasonic. I have paralleled up capacitors to increase current capacity. Leave some space between them for air flow. They will get warm in your application. Use large copper traces or planes to carry the current. http://www.wima.com/EN/pulseselection.htm Selection of Capacitors for Pulse Applications. This might help. Capacitors have a “current rating” much like resistors have a current rating. That comes form power loss, heat rise, ESR*current, dissipation factor. What voltage are you thinking of? | |
But the the higher the frequency the lower the capacitive reaction. So I would guess the limitation is the internal heat rise. Soaking it in oil for cooling would help but it might come down to the duty cycle, it might not be able to withstand 100% or even 30%. | ||
| | (permalink) | ||
Thanks for the idea, i would never have thought of it. Quote:
After some searching i'll think i'll go with illinois capacitor as they seem to have the best ESR for the capacitance and voltage levels i'm going for. The calculated voltage as well as simulated voltage at peak load comes out to about 600-800volt. I intend to incorporate an overvoltage protection circuit that will block further power input if the voltages reach 1kV. The capacitors I'm thinking of using from illinois capacitor are rated for 3kV. I think that should be adequate to handle most spikes or other unforeseen voltage events. To deal with heat i intend to mount the capacitors on 1/4" thick copper plates with heat sinking and forced air cooling on the capacitors. If it still gets too hot i'll use oil cooling as suggested before. The total unit (if my math is correct and the specifications right) will have a working voltage of 3kV, ripple current handling capability of 200A rms, and a "typical" ESR of 0.00046 ohms or 0.46 milliohms. Voltage max during use will be set by the electronics to 1kV. | |||
| OK, first step, make up a company name. Seriously. You can get a lot further with just a company name. People will take you seriously. No one will ever check up on whether your company exists. Give them a call, explain your needs and for god's sake don't be shy about saying what it is. People like that have a high chance of annoying the saleperson. Say "We have a project involving an induction furnace operating at 120khz and calcs show the capacitor bank will need to handle roughly 100 amps RMS at that frequency". Chances are you'd be able to get them to sell you what you need- IF you have the money of course. There's a lot of merit to many small caps. The heat dissipation of one cap at 100 amps RMS is a big issue even if the ESR is very small. However, you need to pay CLOSE attention to the capacitor inductance at 120khz, regardless of whether we're talking about one large cap or many small caps. It sounds like this circuit will be low voltage, high current, right? At 120khz even a small reactive impedance could throw your circuit out of tune or simply prevent high currents from happening.
| Oznog: I already addressed the company question back in one of my posts. As for tuning the circuit i'm not too worried about inductance. The circuit has a feedback mechanism that finds the right frequency through the phase lag of voltage applied to the matching inductor versus the voltage detected in the capacitor. The inductance of the tank circuit actually changes quite a bit upon the insertion of a metal workpiece and so a feedback mechanism HAS to be implemented for this to work at all. The capacitor inductance itself from a mathematical standpoint can be lumped together with the inductance of the output coil and treated as one large inductance. The feedback mechanism should handle any capacitor inductance that i get. | |
| Do I understand right, you are having problems getting high current capacitors? Where are you located? If you knew what I have been doing last month….. I got a semi load of power supplies I designed years ago. Scrapped them out for $0.84/ pound. There were thousands of high current capacitors. I needed the money and no one wanted the parts. I also sold old stock for about $.03/cap. I am going to see the store I sold the capacitors to and I will see what they have. They probably want $1.00 each now. I have some of these. Maybe a bushel of them. .0047uf 1000vac 1250vdc Matsushita (very good capacitor) .022 630V MKP10 6500PF 1500V FKP1 3300PF 2000 KP1 | |
| getting lots of small value, high current capacitors isn't the big problem, its getting the single REALLY high current capacitor (200amps rms) thats the problem. So i'm trying to string together the much more readily available small capacitors to equal the performance of the large one. | |
| Need advice about this AC Line Current Detector | Avocado | Electronic Projects Design/Ideas/Reviews | 6 | 21st March 2008 06:37 PM |
| Expert Stabilised Power Supply with Current Limiting | mechie | Electronic Projects | 36 | 11th March 2008 08:16 PM |
| Current and Conductivity | ElectroMaster | Electronic Theory | 1 | 2nd February 2007 01:50 PM |
| Will this work? | daviddoria | Electronic Projects Design/Ideas/Reviews | 31 | 9th May 2003 05:43 AM |
| why do we need capacitors in parallel with dc motors. | pkshima | General Electronics Chat | 2 | 1st February 2003 07:23 PM |
