Old 30th March 2008, 10:44 PM   #1
Default How Can I detect the phase shift between two sinusoidal signals
Hi .... How can i detect the phase shift between two sinusoidal signals? ... because I want the PIC to calculate the time between the + phase and the - phase ...
Abdullah2121 is offline
Old 30th March 2008, 11:19 PM   #2
What frequency are the signals?
If the frequency is less than about 1o kHz you can read the signals with the ADC and use the timers to measure time difference and period.
Diver300 is offline
Old 30th March 2008, 11:21 PM   #3
Hi ... the frequency of the dignal 1.7 Mhz
Old 30th March 2008, 11:37 PM   #4
I think you can detect the zero cross and figure it out that way. BUt I don't have time to sit down and draw a picture and figure out the relationship between the time spacing of the zero crossings and the frequency.
FOr example:
0 phase shift - the spacings are equal to the period
180 degree phase shift - intdeterminate since you get no signal due to desctructive interference.
dknguyen is offline
Old 31st March 2008, 12:19 AM   #5
Have a read of this thread.
Pommie is online now
Old 31st March 2008, 12:23 AM   #6
You redirect the OP to another thread again in the thread you posted
dknguyen is offline
Old 31st March 2008, 12:34 AM   #7
I know, but for some unknown (and annoying) reason the OP in the first thread deleted his question.
Old 31st March 2008, 01:05 AM   #8
You may consider AD8302, by the way, I am using this chip to perform relative phase difference detection for 1MHz sine wave...
Harros is offline
Old 31st March 2008, 02:14 AM   #9
Use a phase comparator.
http://www.google.co.uk/search?hl=en...omparator&meta=
if I know the answer.
Hero999 is offline
Old 31st March 2008, 02:46 AM   #10
Hi Abdullah2121,
There's a easy way of doing this: You can mix both signals with
the same oscillator signal and pass them to equal low-pass filters.
If you use 1,65 or 1.75 MHz you'll end up with two 50 kHz signals
with the same phase difference. Do I need to say more ?
on1aag.
on1aag is offline
Old 31st March 2008, 07:18 AM   #11
Do you have to differentiate between the phases eg signal 1 is is 10deg leading reletive to signal 2 or is it only a case of knowing what phase difference there is. If it is the last case then ADD both signals thru a opamp(RF type) when both signals are 180deg apart then there will be zero signal and if both in phase, double the signal. Feed the result into an integrator and then use the PIC ADC to read the value.
Super_voip is offline
Old 31st March 2008, 05:28 PM   #12
thanx guys for all these answers ... but all i know that all chips like PLL or XOR gate or phase comparator or the mixer deal only with the square waves not with the sine wave ... if not ,please give me the number of this chip , and i will be greatfull for this ... and I'm sorry if I bother you ..
Old 31st March 2008, 11:56 PM   #13
Talking Mixers and sinewaves ?
Hi Abdullah2121,
I think you should reconsider using the mixers to bring the frequency
of both signals down to manageable levels for the pic. I used 50 kHz
as an example but you could bring the frequency of the signals even
further down by selecting the frequency of the oscillator closer to
the frequency of the signals.
And the signals are all sinewaves.
on1aag.
How Can I detect the phase shift between two sinusoidal signals-90-circuit-diagram.png   How Can I detect the phase shift between two sinusoidal signals-90-input-output-graphs.png output graphs.PNG
ID:	18342   How Can I detect the phase shift between two sinusoidal signals-90-ouput-graph.png
on1aag is offline
Old 1st April 2008, 04:37 AM   #14
you can also use a bandpass filter an ADC. you can remove out-of-band information and alias the signal back to baseband. from there you can determine phase with normal methods. your ADC must have an input bandwidth exceeding the frequency of interest and upper cutoff of the filter.
ideally you will sample at a fraction of the input signal's rate.
also, you can convert the sine wave into a square wave. from there you can use the xor gate. (or ideally two gates and a delayed version of one wave, this allows you to measure down to 0d of difference without worry of narrow-pulses)
cdstahl is offline
detect, phase, shift, signals, sinusoidal
Variable capacitor circuits walters General Electronics Chat 92 7th February 2009 08:08 PM
TL071 phase shift oscillator shirazmacuff Electronic Projects Design/Ideas/Reviews 4 25th December 2007 04:59 AM
out of phase signals cyprio7 General Electronics Chat 14 8th June 2006 01:37 PM
phase shift detection circuit erique82 Electronic Projects Design/Ideas/Reviews 11 8th October 2005 05:22 PM
