| Hi Hans, Instead of three 555 oscillators you could use 3 inverters from a 74C14 Cmos Schmitt-trigger hex inverter IC. The output transistors of the CD4017 will overheat without current-limiting resistors (or just a common one) with your very high 12V supply. A 9V supply is safer and the LEDs will be almost as bright. For 25mA output I would use 74HC4017 ICs with a common current-limiting resistor and a 6V supply. They can be clocked with a 74C14 bunch of oscillators.
| Would it be possible to connect caps across some of the led's so they dim away rather than swith off quickly? If so, what values would be good? 100uF? | |
| Hi Hans, It doesn't matter how much your simulator costs if your concept is wrong. When the counters are counting the leds will be charlieplexed and they will still light, not as bright but they will light. I think you gonna have to make a (few) minor modification(s) to your design. on1aag. | |
If you add a diode in seies with each LED and a capacitor across each LED then the capacitor will discharge fairly slowly into the LED without being discharged quickly when the output of the CD4017 goes low. Try different capacitors.
the caps across the LEDs won't do much. Better use low power MosFets and keep the gate voltage high long enough so the LEDs will extinguish slower. However they won't twinkle anymore. Hans | ||
the longer I look on the schematic the lesss charlieplexing I find. Especially for you here is the difference between multiplexing and charlieplexing. Neither one applies to my suggested circuit. For more info about charlieplexing visit maxim-ic.com. Best regards Hans Last edited by Boncuk; 8th July 2008 at 12:49 AM. | ||
Oops, just selected the wrong power source. Should have been 9V though. I'm not too good at math. Please tell me the difference in making the astables with 3 out of 6 inverters per circuit and using dual timers for the same purpose. My vague calculation results in three ICs in both cases. You'll also have half of an IC leftover for general use. Greetings Hans | ||
| Hi hans, You can make an astable from a single Schmitt-trigger inverter (6 in a package) or from two ordinary inverters.
| That's probably because you used TTL, not CMOS and used to small resistor and too large capacitor values.
| Big change! after all the good advises I've tried to make the astables using a CD106 inverting Schmitt-Trigger. The clocking works well. This way 50 LEDs can be lit with 6 ICs, one for a clock signal oscillator and five clock inhibit oscillators, five ICs for the counters. Using junk resistors and capacitors they might all be of the same value causing different frequencies which are a MUST for that circuit. A tolerance of 40% would make the circuit perfect. Otherwise modify the R and C values slightly for different clock inhibit frequencies. Hi audioguru, did you have your divorce yet? | |
No, I am happily married. Oh, I divorced power-hungry TTL about 25 years ago.
| LED matrix | jagga8 | General Electronics Chat | 0 | 22nd March 2008 02:38 AM |
| 8x8 LED Matrix using 8051 | skydemon2008 | Micro Controllers | 2 | 6th March 2008 06:23 AM |
| LED Matrix Project Debug, Please Help :[ | mekohler | Micro Controllers | 2 | 7th December 2007 07:57 AM |
| P channel FETs vs N channel FETs for LED Matrix applications ?? | tdg8934 | General Electronics Chat | 3 | 9th September 2007 06:17 PM |
| Old Motorola Transmitter Schematic needed | hotwaterwizard | Datasheet/Parts Requests | 1 | 28th July 2006 01:45 PM |
