| i am currently working on a project which is located at this website http://www.electronics-lab.com/proje...007/index.html i am encountering a few problems with this circuit i am not sure how it is supposed work one of the transducers is giving off a noise signaling that it is transmiting but im not sure how to tell if the other transducer is receiving i am also wondering what i should put at point 7 and 8 should i put a relay there? if you see any errors in the schematic please point them out also if anyone has built a working prototype of this ciruit please say so I would greatly appreciate it | |
| Hi Crazyman, C1 shorts the received signal on the schematic but the pcb has it correctly grounded. It looks like the circuit was designed to use a very old opamp for IC1 that needed C3. Now it uses a 741 opamp that does not need C3. Use a switch between points 7 and 8 to latch the output when it is turned on. When it is turned off then the beeper or relay at the output will activate for each movement the circuit detects. I don't think it will be sensitive and I don't think it will detect somebody wearing a sweater or a coat. Unless they move in front of a close wall.
| will it detect my hand if i move it in front of the transducers | |
| I don't know if your hand reflects much ultrasound. It will block a reflection from a wall behind it. I don't think the project is sensitive. Inexpensive PIR motion detectors that people have for their driveways and alarms pick you up 15m away. They use infrared, not ultrasound.
| My ultrasonic rangefinder "sees" my hand just fine out to about 1-1.5 meters, but detects harder and flatter objects better at a distance. It can see a wall up to just under 3 meters away, and appears to be limited mostly by the timeouts I set in the code. I don't know about your circuit; mine is just a simple 8051 uC using opposing output pins to drive a piezo transducer plus an op-amp receiver to detect the bounces. Torben | |
| Uni Project Advice | 2-tone | Electronic Projects Design/Ideas/Reviews | 7 | 18th October 2007 01:11 AM |
| My professor screwed my final electronics project! | kungfusansu | Electronic Projects Design/Ideas/Reviews | 21 | 26th August 2007 10:57 PM |
| FINAL YEAR PROJECT! | erique82 | Electronic Projects Design/Ideas/Reviews | 18 | 15th April 2007 11:09 AM |
| Low power radar (BEng project) | IacovosGio | Electronic Projects Design/Ideas/Reviews | 4 | 17th October 2005 06:51 PM |
| radar project | cyberpunk | Electronic Projects Design/Ideas/Reviews | 1 | 30th March 2003 02:55 PM |
