hi
In my circuit I had a 230/12. rectified, and filtered(using 470uF), supply which supplies an electrmagnetic relay of 12v 200 ohms. taking approximately 80 mA. Now I need to tap 5.1 V, 9.1 V and 15V from the same source, for which i used Zener diodes. 5.1V zener is for charging 4700uF Capacitor. 9.1V is for 555timer and 15V is for IC4011. Accordingly what are the resistors to be used? I used 10k resistor for each zener. Is it OK? also, From pspice i found that filtering capacitor(470uF) power dissipation is having around 15 watts pulses. why is it so? |
Can you post a drawing on how you have wired the zener circuits etc.?
Eric "Good enough is Perfect" PIC tutorials: Gramo's: www.digital-diy.net/ Bill's: www.blueroomelectronics.com/ |
Now iam sending
the exact drawn circuit's jpg attachment. u may see it. view this after saving. Last edited by kris1; 29th March 2008 at 08:26 AM. Reason: original circuit |
Just typed in a reply.. system crash so I'll try again. The 10K and 5.1V zener will charge the capacitor slowly to about 5v. The 10K with the 9.1V for 555 [is it TTL?] is much too high. The 10K and 15V zener will NEVER give you 15V, you cant get +15V from +12V in this way. If you tell us what the project is for, we could suggest other ideas..
sir as ac when rectified gives the peak voltage as its output. i.e.,
12 *1.414=16.968 volts(approximately) as dc voltage. then the filtering capacitor taken is of 470uF 35v. will smooth it to about 15 v. My doubt is whether we can connect these different zeners in parallel. And whether the remaining two zener resistors are ok or not . |
While it is easy to purchase and use 7805, 7809(or their 78L counterparts with input &output pin reversal), 15 volts is rather difficult after loading the the rectfied supply.
Perhaps it is preferable to try out boost converter version of lm257x series. How ever, CMOS chips work well at 12V also. 15V is rather on the higher edge of its use.
Regards, Sarma. |
The simplest solution would be a 78L05 and a 78L09. The 4011 will happily work with 9V.
Mike. |
Lets take it one zener at a time. Consider the 9.1V for the 555 timer. Q1.. is the 555, CMOS or TTL.? Q2. What is the 555 output driving at what current.? Like to help.
hi kris,
Did a Googling, came up with these two links. Use the calculators on the links for you zener network, lets know how it goes.. http://www.reuk.co.uk/Zener-Diode-Voltage-Regulator.htm http://www.woodsbas.demon.co.uk/calcs/diodes.htm
Consider the 9.1V for the 555 timer. Q1.. is the 555, CMOS or TTL.? Q2. What is the 555 output driving at what current.? 555 is CMOS 555 is driving the input of 4011 ic i.e., two common inputs of NAND gate. The output of NAND gates, which is acting as nor gate, drives the transistor base(BC547) |
Assume the 555 and the logic and the base drive require 15mA and that the supply is +12v. Allow an additional current of 5mA into the zener, equals 20mA total. So Resistor = (12 -9.1)/.02 = 147R,, npv = 150R If you had a supply of +Vs then the formula is Res= (Vs -Vz)/ (Iz + Iload) Set Iz= 5mA and calculate the current required by the rest of the circuit the zener output is driving. Does this explain this part OK.?
The 4011 is driven by the C555 so they both must have the same supply voltage. If they both use 9.1V then the current in the 10k resistor is too low for the 4011 to drive anything. The current is only (15V - 9.1V)/10k= 0.59mA.
If the 10k resistor is changed to 1k then there is 6mA available for the 4011 to drive the transistor plus a few mA for the zener diode.
Uncle $crooge |
Hi Kris,
Downloaded your drawing, that you added to a previous post. I have added some components marked in BLUE and voltages in RED. Reposted your circuit to help other members locate easier. Can you explain exactly what you are trying to do with this circuit.
Eric "Good enough is Perfect" PIC tutorials: Gramo's: www.digital-diy.net/ Bill's: www.blueroomelectronics.com/ Last edited by ericgibbs; 7th July 2008 at 11:23 AM. |
Q1 & Q2 for High voltage and low voltage cut respectively.
the nand gates provide drive to base of transistors. The connection is such that the relay cannot energise by itself. the transistor Q3 provides the closed path if it is switched on by timer. Initially the timer will be getting supply so its output will be high so it may immediately turn on Q3. But I mean to protect he equipment from sudden trip and resumption. so i should have a time delay. timer output will be high for a certain time & then goes low. So i used one NAND gate here as inverter. i.e., providing low input to Q3 initially & then high after a TIME DELAY. This will happen only if Q1 &Q2 are in On state. Immediately after switching on of relay, timer will not get any supply. Q4 is pnp and will be in off state as long as the relay is in energized state. so will be the buzzer. Hence it gives brief alarm during power failure; continuous beep for high/low voltages. Also beeps after power restoration until circuit is turned ON automatically. The components and some part of composition was not totally mine. But the logic of this connection is my thought. Thank you for your support. and thanks to electro-tech. Kris |
hi kris,
Saved your descriptive text OK. I have gone thru part of the circuit already, there are many parts of the circuit that have problems. Do you have the spec on the buzzer, volts/current.? This design could take some time to sort out.
| Good Electronic Supply's Sites, Everyone Come On In! :P | Electric Rain | General Electronics Chat | 44 | 27th August 2007 11:05 PM |
| parallel diodes | evandude | General Electronics Chat | 13 | 23rd March 2005 12:26 PM |
| Other reasons for parallel resistors | pandaemonium | General Electronics Chat | 18 | 23rd December 2004 07:42 AM |
| zener diodes | Screech | General Electronics Chat | 4 | 16th May 2004 06:25 AM |
| zener diodes & rectifier diodes | mozikluv | Datasheet/Parts Requests | 2 | 16th September 2003 05:17 AM |
