Old 28th March 2008, 02:37 AM   (permalink)
Default Can I parallel up two of the same UPS units?
It must be possible to parallel up to UPS units of the same type & Wattage?
I did it it with transformers, too. Of course one needs to get the correct wires together, according to the direction of the winding/flux.
I can understand that two unit of different output cannot be paralleled up, because the total output will be limited to the smallest unit's output, like with resistors.
jjj is offline
Old 28th March 2008, 02:52 AM   (permalink)
A UPS has an AC output. Two will have their oscillator frequencies slightly different resulting in one having a negative momentary output and the other having a positive momentary output. The load will get nothing but the inverters will blow up.
Mains transformers operate at exactly the same frequency.
Maybe you can sync one UPS inverter to the other.
audioguru is online now
Old 28th March 2008, 04:34 AM   (permalink)
I agree with Audioguru. Without a synchronizer you WILL blow up your UPS equipment.
SPDCHK is offline
Old 29th March 2008, 02:55 PM   (permalink)
They will blow up if they aren't designed for it because the won't be in phase with each other.
Some UPSes can be paralleld, one is set as the master and the other is set as slave. The slave sychronises itself with the master and suplies the same output voltage and current.
Check the datasheet, it normally isn't as simple as paralleling the outputs, you sometimes have to connect a communications port or something else.
Screen name: Aloone_Jonez
Hero999 is offline
Parallel Port & Microcontroller Omar.M General Electronics Chat 10 14th August 2007 10:31 AM
To Parallel Or Not To Parallel ScuzZ General Electronics Chat 5 28th January 2007 03:29 PM
lithium-ion in parallel justDIY General Electronics Chat 8 29th June 2006 08:37 PM
PIC 2 PC: Parallel (Port) Read Electrix Micro Controllers 8 31st July 2005 05:24 PM
USB to Parallel HELP! PLZ! demestav General Electronics Chat 11 13th April 2005 12:44 AM
