| For my gcse project think of a basket ball counter that counts the amount of time the ball passes through the hoop. I think ill use a IR beam and when the IR beam is broken it will send an electrial impulse to the counter. On a LED display the number 1 will light up the if the ball passes through again number 2 and so on. Should be pritty simply i think but sorting out where the ir beam will go and where the wires will go however theres my project. | |
| If you put the beam at the rim it may count balls that go partially in and then bounce back out. You may need a delay circuit that doesn't count unless the beam is broken for a given amount of time. The minimum is probably the time it takes for the ball to go through the hoop from a high arched shot that goes cleanly through the hoop. | |
Why dont you count the balls as they drop out of the bottom of the net.??
| that might sense balls that brush the net though. i would use 2 sensors, one on the rim and one on the bottom of the net, so that it must pass through both to count | |
| Dual counter | bananasiong | Micro Controllers | 45 | 24th March 2007 03:49 AM |
| How we can do it in Assembly..Help Needed | Ayne | Micro Controllers | 37 | 29th December 2006 06:49 PM |
| Input Counter Pic16F84A (Code problems) | loco | Micro Controllers | 4 | 26th September 2006 02:19 PM |
| [help] Power consumption issue on bullet counter project * | Lanzer | Electronic Projects Design/Ideas/Reviews | 13 | 26th August 2005 07:06 AM |
| Crude assembly counter | Mark Lazarides | Micro Controllers | 5 | 28th February 2004 08:22 PM |
