Old 27th March 2008, 04:31 AM   (permalink)
Default Frequecy control for AC motor.
Hi i need to control a very small rated AC motor using frequency.
I thought of controlling it using UPS circuit... In normal system's UPS, the frequency would set for 50Hz in my country... I thought of putting the veriable resistor insted of fixed one..
I have not tried yet. would it work???.. Then one more circuit using 555 also availble.. Let me good circuit to control frquency.. thanks.
mytech is offline
Old 27th March 2008, 05:26 AM   (permalink)
Depends upon the amount of speed control you need. You shouldn't go much below 50Hz since the transformer would likely saturate and draw high input currents or kill the inverter power transistors. You could probably go above 50Hz. The limit would likely be how fast the inverter transistors switch and how hot they get.
crutschow is online now
Old 27th March 2008, 11:34 AM   (permalink)
If you use a modified sinewave and reduce the duty cycle, it's possible to go under 50Hz but don't expect great performance.
Screen name: Aloone_Jonez
Hero999 is offline
Old 27th March 2008, 11:44 AM   (permalink)
Is the motor a type that can be adjusted by modifying the frequency ( is it's rotational speed synchronized with line frequency)? Some small AC motors are more universal.
If it will respond to changes in frequency the next question would be will it's power/torque characteristics meet or exceed your requirements at all of the speeds you have planned? If your application is constant duty - can the motor tolerate these conditions?
stevez
stevez is offline
Old 27th March 2008, 12:36 PM   (permalink)
Thaks for your replies..
Actually i am just going to show the demo.. So i can use any type of AC motors..
I too have the same question.. When i reduce the frequency what would happen to torque & power.. Will it remains same or will give poor output??..
mytech is offline
Old 27th March 2008, 12:46 PM   (permalink)
If you have a choice then don't use any type of AC motor, use a universial motor and don't reduce the frequency, use phase control.
Hero999 is offline
Old 27th March 2008, 01:02 PM   (permalink)
Power is more or less torque multiplied by rotational speed. If you reduce the speed you'd have to increase the torque of the motor to keep power constant - so it's likely that power will drop with speed. The change in torque is quite dependent on the motor and the drive but probably drops as well.
My work occasionally calls for varying the speed of a motor - usually a large (10 hp and up, 3 phase) industrial motor. There are some general rules that describe the behavior of these motors but the construction of smaller motors is such that these general rules may not be a good guideline. I am the mechanical engineer who has to work with the electrical engineer on motor and drive selection. It is not unusual to find that the capabilities of the motor are ok at full speed but fail to meet needs at reduced speeds.
stevez
stevez is offline
Old 28th March 2008, 09:50 AM   (permalink)
Thats the ticket! will do the trick nicely.
bloke_man is offline
Project: DC Motor Control (using a single switch) arijit18 Electronic Projects 16 7th December 2008 10:37 PM
Please help me to build a bipolar stepper motor control thusithk General Electronics Chat 7 5th March 2008 03:36 PM
Electronics n00b Needs Advice on Motor Control Gabe Billings General Electronics Chat 6 6th August 2007 03:24 PM
Motor Position Control Problem YAN-1 Electronic Projects Design/Ideas/Reviews 10 31st March 2006 03:03 PM
Boat motor control staticpony38 Electronic Projects Design/Ideas/Reviews 2 31st May 2004 03:02 AM
