| Hi all, this is my first post. I have a small PIC project that is to read the NMEA 0183 strings from a GPS from the serial port and then, extract some values from it and then, process it and then, turn On/Off a relay on the pcb. Wich PIC is required ? I'll use C on MPLAB. Someone has any hints on how to read the ASCII data from the serial port ? Many thanks! | |
| Any PIC could do it, NMEA is only 4800baud. A PIC with a USART would make the programming simpler. The 16F628A or 18F1320 would both be good choices IMO. | |
| It would be easier to use a PIC with enough memory for the whole of the GPS sentence. That way, you can have a simple program to collect the data from the EUSART one character at a time, and store it in memory. Then you can test the program that looks at the data using MPLAB. I would use an 18F series PIC. | |
The first one start at 15 for 8 char lenght, the second one start at 26 for 9 char lenght and the third one start at 38 for 3 char lenght. Non stop collect. That is all. From that data collected, i want first to look at the third one and use it to activate a pin 5 volts somewhere on the pcb. I think this is an easy project but i've never done anything yet on a micro processor. :-( I'll need some help and hints to begin the project. Thanks! | ||
| What have you programmed previously? Mike. | |
| I would suggest that you install MPLAB and the C18 compiler and have a play with some of the C18 code posted here (Search C18). To get the string into memory will be something like, Code: char chr;
ram char message[64];
ram char *pointer;
pointer=&message[0];
while(chr=GetRS232()!=10){
*pointer++=chr;
} The initialisation and reading of the RS232 data is covered in various threads here. Hope that gets you started. Mike. | |
| I don't know if i can do this here but since i really need this fast, i am willing to Paypal money to someone who is interested to do enough code that let me finish or fine tune it after. Anyone ? PM me. Thanks! | |
| An error in pic16f84a, why? | Zener_Diode | Micro Controllers | 6 | 11th April 2004 03:55 AM |
| Reading data from ADC output | belinda_sg | Micro Controllers | 3 | 19th February 2004 06:51 AM |
| 8051 microcontroller reading data from serial port | godatguitar | Micro Controllers | 11 | 17th February 2004 09:04 PM |
| pc keyboard interfacing problem | econsyst | Micro Controllers | 0 | 8th November 2003 09:28 PM |
| USB data aqusition | discofunk | General Electronics Chat | 2 | 29th July 2003 12:01 PM |
