Old 24th March 2008, 06:18 PM   (permalink)
Default 600W battery charger design
Hi all,
My battery charging knowledge is limited, but I know a bit about SMPSU
design.
I was wondering what topologies and silicon could be used to deliver
substantial powers used to charge a 300Ah 24V lead acid battery bank
(employing three stage charge curve like :-
http://www.electroparts.com.au/images/bc_chart_large.jpg).
I have thought:-
1) Front end boost circuit, to give unity PFC and constant voltage
over wide input voltage range
1.1) But have read that due to high peak currents can be unusable at
powers above 150w (onsemmi switch mode PSU reference manual SMPSRM/D
rev 3B July 2002 page 9)
1.2) Should I parallel up boost circuit or go to duel-phase for higher
powers (not just components entire circuit)
1.3) What effect would the input frequency swing have on the boost
circuit?
2) Probably a full isolated bridge with synchronous rectification.
3) what effect does the three stage charge cycle have on output
voltage and current the PSU supplies (told you I don't know much about
battery charging)?
4) Are there any good guides for designing lead acid battery chargers
within this power range?
5) any application guides / circuits on the net for this type of
application?
specification:
Input voltage: 90 - 260 VAC RMS
Input frequency: 40 - 100 Hz
Nominal output power: 600 W +/- 5%
Nominal output current: 25 A
Rated battery voltage: 24 VDC
Operating amb. temperature: -25ºC to +40ºC
Efficiency: >85%
Cooling: forced air and none forced air
Package:187mm x 116mm x 50mm
reggie is offline   Reply With Quote
Old 24th March 2008, 07:42 PM   (permalink)
I couldn't access your picture, please attach it.
To float charge the battery, the output voltage needs to be 27.6V.
Just make sure the SMPs is current limited.
Screen name: Aloone_Jonez
Hero999 is online now   Reply With Quote
Old 24th March 2008, 07:56 PM   (permalink)
sorry about the jpg. The charging cycle chart can be seen on this page:
http://www.electroparts.com.au/page.php?x=3&i=2&o=4
Old 26th March 2008, 02:24 AM   (permalink)
if you don't want to build one i would use this batteyr charger
http://www.meanwell.com/search/pb-1000/default.htm
carmusic is offline   Reply With Quote
Old 26th March 2008, 11:33 AM   (permalink)
Thanks for the link carmusic, but i do want to design one.
Any ideas?
MP Lab Program Help bamafan54 Micro Controllers 3 19th October 2007 02:53 AM
Solar battery charger with moving panel Hanford Electronic Projects Design/Ideas/Reviews 6 8th October 2006 01:38 PM
Battery charger for mobile phone Motorola 2PAC Mafia General Electronics Chat 0 4th October 2005 03:19 PM
battery charger circuit for 9v pp3 battery anyone ? badflyer Electronic Projects Design/Ideas/Reviews 0 27th October 2003 07:35 PM
2x12Volt 60Ah Car Battery Charger Sarac Electronic Projects Design/Ideas/Reviews 11 21st January 2003 04:52 AM
