Thanks to Hero for getting me this far! I want to use the attached for a timer circuit, so far got most of the componants and hurdles as well as the rest of the (exterior to the timer) circuit sorted. However.... I need to trigger (I think this is an edge trigger?) via loss of Vs (12v). Normally, the 12v will supplied. I want the timer to produce it's output once only when the 12v is cut. Note cut, it isn't switched to 0v, it's simply a loss of a Vs voltage to the trigger. Currently I think this circuit is set up to trigger via a 0v feed when I need it to trigger by loss of 12v (output on break). Can anyone suggest a modification or direct me to a good web page on designing edge triggering? Thanks, Greg.
__________________ New to making electronic circuits but with a sound electrical/faultfinding and basic componant knowledge. Looking forward to learning! | |
This will work. P.S. In furure, please restrict the discussion of a circuit to just one thread; multiple threads can get confusing.
| 555, edge, loss, trigger |
| 555 timer help | thekyguy11 | Electronic Projects Design/Ideas/Reviews | 23 | 9th October 2009 09:21 PM |
| Creating Complex Camera Trigger | Drew Fulton | Electronic Projects Design/Ideas/Reviews | 5 | 26th April 2008 06:59 PM |
| How to properly do PCB edge connections in Eagle? | toodles | Electronic Projects Design/Ideas/Reviews | 2 | 10th April 2007 11:36 PM |
| Usinging RF Reciever's output to Trigger a 555 one shot | RaG | Electronic Projects Design/Ideas/Reviews | 1 | 2nd January 2005 11:26 PM |
| electronic switch to enable a camera to fire a flashgun | tony ellis | Electronic Projects Design/Ideas/Reviews | 10 | 30th September 2004 11:19 AM |
