Old 23rd March 2008, 05:42 AM   (permalink)
Default Musical Project
I play in a band and am in the process of designing some of our visual effects. What I'm stumped on is this one...
I want to trigger a ring of LED's around the ring of one bass drum when it is hit, but when the snare is hit then use a different color of LED's. i want to use 4 different color groups then recycle back to the first set. other effects on the drum are going to be used but if i can just figure out the triggering circuit i can replicate it for the others. i have to be concerned if a sound trigger is used in the drum to make sure it isnt so sensitive that the ambient noise will set it off. ive considered using some sort of inertia switch for the trigger, but the switch between colors has me stumped.
im an industrial electrician with plenty of experience reading diagrams, but my experience w/ electronics is limited, so if you have any suggestions, please dumb them down for me! still trying to learn this branch of electrical work.
480threephase is offline   Reply With Quote
Old 23rd March 2008, 01:04 PM   (permalink)
If you attach a small speaker to the drum body, facing inward, it will act as a transducer when the drum is hit. Then you can use that to trigger a basic digital circuit to do the leds.
"Everything that is done in the world is done by hope." -Martin Luther
"There are two ways to live your life. One is as though nothing is a miracle. The other is as though everything is a miracle."-Albert Einstein
Analog is offline   Reply With Quote
Old 24th March 2008, 04:22 AM   (permalink)
ok. i understand that much, now how do i choose the right size speaker and is there a way to adjust the sensitivity of the speaker so that it doesnt pick up the ambient sounds. we have 4 other instruments playing out of 1000 watt system.
Old 24th March 2008, 08:07 AM   (permalink)
3v0
Analog:
Can he tell the difference between a snare drum and a non snare with band pass filters.
Or go low tech and put a sensor on each drum of interest.
3v0 is offline   Reply With Quote
Old 24th March 2008, 11:40 AM   (permalink)
It's best to use a piezo disc fixed to each drum, they're cheap and easy to get hold of.
Screen name: Aloone_Jonez
Hero999 is online now   Reply With Quote
Old 24th March 2008, 04:34 PM   (permalink)
that was kinda what i was leaning towards was either some sort of inertia sensor on the heads or a piezo switch, then i could figure out the logic on my own. appreciate it guys.
Old 24th March 2008, 05:05 PM   (permalink)
they make drum triggers that attach the the drum heads. im not sure how they work but you could probably google drum trigger and learn a lot
Gaston is offline   Reply With Quote
Old 25th March 2008, 05:53 PM   (permalink)
cool. thnx alot. i found some for about 7 bucks a peice. essentially they are just piezo transducers that input into a drum module, so i could get some piezo transducers and just use them to gate my circuit. i think ive got it figured out now. thanx everyone
Old 26th March 2008, 11:22 AM   (permalink)
You can get piezo transducters for much less than that. Maplin isn't the cheapest place and they sell them for less than that.
http://www.maplin.co.uk/module.aspx?...=3202&doy=26m3
Old 26th March 2008, 04:40 PM   (permalink)
Make sure you insulate them from too much vibration or shock with foam or something. Compared to a drummer, those things are amazingly fragile. Especially if you're playing live. Also, be careful how you mount them as it's easy to get cross-triggering from one drum to another via the hardware (depending on how the drums are mounted).
Torben
Torben is online now   Reply With Quote
Old 27th March 2008, 05:59 AM   (permalink)
the pricing was for a drum trigger set up for an electronic processing machine. i didnt price the transducers. im probably going to mount them towards the outer rim inside the drums and use adhesive foam to cushion them, then just go from there
Uni Project Advice 2-tone Electronic Projects Design/Ideas/Reviews 7 18th October 2007 12:10 AM
My professor screwed my final electronics project! kungfusansu Electronic Projects Design/Ideas/Reviews 21 26th August 2007 09:57 PM
Help needed for a 'musical bike' project. Semaj Electronic Projects Design/Ideas/Reviews 4 15th November 2006 12:57 PM
A Microcontroller based Analogue Waveforms Analyzer Project km Electronic Projects Design/Ideas/Reviews 76 30th June 2004 06:39 PM
I need a project idea based on my strength or interest. :) janetsmith2000@yahoo.com Electronic Projects Design/Ideas/Reviews 10 11th November 2003 09:33 AM
