I just Made Up The Inverter Circuit That Shown Belw Its Work Very Gd But When I Connect Any Load There A Drop Voltage , So I Increase The Frequency The Drop Decrease The Equestion ; The AC Load Like TV, PC .... Have Any Side Effect From This Frequency ... And Isn 't There Any Way Else To Keep The Voltage Constant Shams .........
Wrong!!!!!!!!!!!!!!!!!!!!
Experienced Member
The output of your inverter has a square-wave. Many electronic products won't work because their power supply works from the higher peak voltage of a sine-wave.
The circuit is too simple to regulate its output voltage. A cheap poor quality transformer has poor voltage regulation. Maybe your transformer is designed for 60Hz so has a small core. Then it won't work well with 50Hz.
Uncle $crooge |
Experienced Member
Today it just does not make sense to use a low frequency transformer. It makes much more sense to convert to high voltage at high frequency and then use a full or half bridge to obtain a "modified sine wave". That is what all commercial units do.
Experienced Member
You can have a look at this AppNote from Intersil:
http://www.intersil.com/data/an/an9611.pdf An Inverter with HIP4082 and MOSFETs Petr |
| Inverter DC to AC... | yiefang | Electronic Projects Design/Ideas/Reviews | 7 | 12th May 2008 01:51 PM |
| dc 12v to 48vdc | anjaan | Electronic Projects Design/Ideas/Reviews | 6 | 19th February 2008 09:54 PM |
| dc mode to ac mode | orkeet | General Electronics Chat | 8 | 12th February 2008 10:34 AM |
| Ac to DC | jdahl | General Electronics Chat | 8 | 6th February 2008 05:41 PM |
| Convert 12V DC to 220V AC | micpic | Electronic Projects Design/Ideas/Reviews | 17 | 15th September 2007 02:03 AM |
