Old 22nd March 2008, 10:29 AM   (permalink)
scuppers is on a distinguished road
Default How can I get 3 volts to trigger a short circuit??(skateboard timer)
Hi Guys and Girls..
Long time listener..first time caller.
I'm rigging up a wireless timer for slalom skateboard racing, using a wireless door bell and a stopwatch..
I've found on the circuit board some terminals that go from 0.1 volts to 2.8 volts when the button is activated..and this needs to somehow trigger a short circuit to stop start the stop watch...(the door bell controller uses 3 X 1.5 AA batteries)
I can only find relays that activate on 5 volts..
can I use a chip so that this 2.8 volts can activate a gate and give 5 volts separate power supply to a relay, then in turn activate the stop watch?? or can I simply step up the 2.8 v to 5 v somehow??
Any ideas would be most appreciated cause i'm kinda stuck ....but suspect there's an easy way around it...
scuppers is offline   Reply With Quote
Old 22nd March 2008, 10:33 AM   (permalink)
Experienced Member
raviram87 is a jewel in the roughraviram87 is a jewel in the rough
how abt using a comparator instead.... set the reference to say some 2V.. when the output of ur circuit goes to 2.8V, the comparator will output a HIGH voltage... which of course u can set to 5V and do wat u want....
raviram87 is offline   Reply With Quote
Old 22nd March 2008, 10:38 AM   (permalink)
Thanks raviram87...I'm by no means an electronics expert..but will now definitely be looking at comparator..cheers for your reply and advice !!
Old 22nd March 2008, 10:40 AM   (permalink)
Experienced Member
no probs... all the best!
Old 22nd March 2008, 10:44 AM   (permalink)
Experienced Member
Bavananth is on a distinguished road
Hey won't his idea work? "Using two not gates with 6V Vcc ". Thats cheaper?
Bavananth is offline   Reply With Quote
Old 22nd March 2008, 11:45 AM   (permalink)
thanks Bavananth..I'm gonna try both suggestions..a comparator and also 2 not gates to trigger 6v cc....and hopefully learn something along the way..thanks for replying
Creating Complex Camera Trigger Drew Fulton Electronic Projects Design/Ideas/Reviews 5 26th April 2008 05:59 PM
Help with timer and interrupt please.. AntRoFiZ Micro Controllers 2 29th May 2007 11:48 AM
:: Timer 2 Woes :: suby786 Micro Controllers 2 5th May 2007 11:13 AM
12 volts from two 9 volt batteries sandmantoy Electronic Projects Design/Ideas/Reviews 9 22nd April 2006 01:02 PM
countdown timer code ah_Hui Micro Controllers 0 26th April 2004 05:30 PM
