Old 22nd March 2008, 10:26 AM   (permalink)
Default Room Noise detector explanation needed
hi ,can any one please help me in explaining the room noise detector circuit and how each component is designed
i have attached the circuit diagram
Parts:
R1____________10K 1/4W Resistor
R2,R3_________22K 1/4W Resistors
R4___________100K 1/4W Resistor
R5,R9,R10_____56K 1/4W Resistors
R6___________5.6k 1/4W Resistor
R7___________560R 1/4W Resistor
R8_____________2K2 1/4W Resistor
R11____________1K 1/4W Resistor
R12___________33K 1/4W Resistor
R13__________330R 1/4W Resistor
C1___________100µF 63V Polyester Capacitor
C2____________10µF 25V Electrolytic Capacitor
C3___________470µF 25V Electrolytic Capacitor
C4____________47µF 25V Electrolytic Capacitor
D1_____________5mm. Red LED
IC1__________LM358 Low Power Dual Op-amp
Q1___________BC327 45V 800mA PNP Transistor
MIC1_________Miniature electret microphone
SW1__________2 poles 4 ways rotary switch
B1___________9V PP3 Battery
Clip for PP3 Battery
Device purpose:
This circuit is intended to signal through a flashing LED, the exceeding of a fixed threshold in room noise, chosen from three fixed levels, namely 50, 70 & 85 dB. Two Op-amps provide the necessary circuit gain for sounds picked-up by a miniature electret microphone to drive a LED. With SW1 in the first position the circuit is off. Second, third and fourth positions power the circuit and set the input sensitivity threshold to 85, 70 & 50 dB respectively.
Current drawing is <1mA with LED off and 12-15mA when the LED is steady on.
Use:
Place the small box containing the circuit in the room you intend to measure ambient noise.
The 50 dB setting is provided to monitor the noise in the bedroom at night. If the LED is steady on, or flashes bright often, then your bedroom is inadequate and too noisy for sleep.
The 70 dB setting is for living-rooms. If this level is often exceeded during the day, your apartment is rather uncomfortable.
If noise level is constantly over 85 dB, 8 hours a day, then you live in a dangerous environment.
vibish is offline
Old 22nd March 2008, 06:51 PM   (permalink)
Hi Vibish,
As I said on the other website, I don't think the circuit works properly:
1) It is missing a diode across R12 to discharge C4 when the signal charges it through the base-emitter junction of the transistor.
2) I think the circuit needs a peak detector circuit.
It is a simple circuit and I explained how it works on the other website.
You need to understand basic electronics for you to see how the value of each part was selected for the design. Ask your teacher to teach you.
audioguru is online now
Ground Noise jnnewton Electronic Projects Design/Ideas/Reviews 5 30th November 2007 08:22 PM
OpAmps, breadboards, and noise questions BeeBop Electronic Projects Design/Ideas/Reviews 8 5th April 2006 06:22 PM
choke filter zhi_yi General Electronics Chat 23 10th November 2005 02:49 PM
Measuring noise with O'scope Optikon General Electronics Chat 8 8th January 2005 11:25 PM
Electronic Noise and Analysis (Experts please help) Optikon General Electronics Chat 19 14th December 2004 06:16 PM
