| hi there everyone I am trying to build a prototype of a self powered rfid tag with a temperature sensor attached to it. The prototype is to be used with low frequencies and it should use inductive coupling to transmit the power from the reader to the transponder to power up the circuit. At the same time to transmit the data back to the reader which is going to be the 8 bit coming out of the temperature sensor. The transmission of the data is going to be done using load modulation ( an on/off switch controlled by a pic lowpower microprocessor ). the checking for errors will use UART in the pic microprocessor. I am having real problems understanding how the whole system will be designed. I studied all aspects of the antenna and built it and afterthat comes the front end rf circuit as i guess which, the microprocessor and i need a control unit as well. if anyone got any ideas or knowledge about how to build up the device please let me know as i would really appreciate it and the attachment shows the prototype needed to construct. | |
| It this battery powered? I briefly looked into stuff like this and there was one system out there that was powered this way, but it wasn't battery powered because of the power requirements needed for the inductive coupling. | |
| 8051 Temperature Sensor | Meesam | Electronic Projects Design/Ideas/Reviews | 5 | 6th December 2006 11:37 AM |
| Temperature sensor circuit (AD592) | Flying | General Electronics Chat | 0 | 24th July 2006 04:40 PM |
| temperature sensor calibration | dukebound85 | Micro Controllers | 11 | 21st November 2005 11:28 PM |
| Remote IR temperature Sensor | chtan23 | Micro Controllers | 1 | 5th September 2005 05:57 PM |
| temperature sensor | farzana | Electronic Projects Design/Ideas/Reviews | 1 | 23rd September 2004 08:59 AM |
