Old 21st March 2008, 09:16 PM   (permalink)
Default Tilt Sensor Project
Hi there,
I'm looking for a tilt sensor / circuit that can detect very slight movement, i would imagine a couple of degrees either way, which would intern trigger voltages to an LED array similar to this:
http://img-europe.electrocomponents....R247305-01.jpg
so at level the middle LED's light. Tip the sensor to the right and the right hand LED's light etc.. shall we say and electronic spirit level. Does anyone know if this is possible or are there any purchasable circuit kits out there which would do such a job
James
ironside82 is offline
Old 21st March 2008, 11:03 PM   (permalink)
Default The Tilt Sensor Itself.........
Originally Posted by ironside82
Hi there,
James
The tilt senor itself could be made from a short slightly bent plastic tube with a steel ball in it. On the outside would have to wind two coils side by side that would be part of two oscillators. As the ball moves the frequency of the oscillators would change representing the tilt.
It would be similar to what is called linear displacement transformers.
That is all I have time for..............
Rolf is online now
Old 21st March 2008, 11:17 PM   (permalink)
If you can get an analog voltage out of whatever tilt sensor you chose (have you Googled: Tilt Sensor?), you can use a LM3914 IC to convert the voltage to drive your LED display.
http://www.national.com/ds/LM/LM3914.pdf
You may have add an opamp or two to get the scale and zero adjustable, but it's very do'able.
Ken
KMoffett is offline
Old 21st March 2008, 11:20 PM   (permalink)
"intern" should be"in turn" (an intern is something completely different, kind of like a student)
THere are electrolytic tilt sensors that do that very accurately (in static conditions), but they cost a lot. Like $300 or so from Spectron Sensor (although the one I have in mind is a 2-axis one). A accelerometer or inclinometer IC would also do the trick.
dknguyen is online now
Old 22nd March 2008, 08:56 AM   (permalink)
Hi there,
James
From your description of the project it appears that you just require an indication of tilt. Say 2deg either side of the horizontal, not any intermediate degree of tilt. ??
Buy two low cost tilt sensors [look at the Maplin web site] and mount them end to end in such a way that a 2deg tilt to the right closes one and a 2deg tilt down left closes the other.
The switches in the sensors will drive a LED via a limiting resistor.
A little extra logic would light an LED in the mid position.
Do you follow this.?
Eric
"Good enough is Perfect"
PIC tutorials:
Gramo's: www.digital-diy.net/
ericgibbs is offline
Old 22nd March 2008, 10:59 AM   (permalink)
I used to do this with mercury switches salvaged from old thermostats. May not be an environmentally friendly thing to do, unless you can be very sure they would not get broken.
3v0 is offline
Old 23rd March 2008, 11:42 AM   (permalink)
I second the mercury switches.
Always follow the KISS principle.
A conclusion, is the point reached when you stop thinking.
Centretek is offline
Old 23rd March 2008, 08:28 PM   (permalink)
The mercury switch method sounds like it could be a goer. I guess its just a case of getting those mountings accurate.
Thanks for all your help
Old 24th March 2008, 12:40 AM   (permalink)
Default Tilt sensor
Hi all,
a tilt sensor isn't accurate enough. There are lots of acelleration sensors with different resolutions - up to 0.1 degree - on the market (e.g. maxim-ic.com). They are available from one axis to three, to measure X,Y and Z movements or displacements. Interfacing them with a small MCU it's quite easy and cheap to constuct a "spirit level" like it is used in the construction business.
In the meanwhile I will search for a project using a one axis sensor and an LM3914 to indicate tilt.
Regards to all
Hans
Boncuk is offline
Old 24th March 2008, 01:09 AM   (permalink)
Mercury switches are banned in the EU.
You can buy non-mercury switches that use a ball bearing though.
Screen name: Aloone_Jonez
Hero999 is offline
Old 24th March 2008, 01:13 AM   (permalink)
Default electronic spirit level
Hi ironside82,
here is what you have been looking for. This circuit uses an ADXL05 (Analog devices). It's obsolete, but probably you can find one - or a suitable substitute.
It is very important for accurate measurements that the longitudional axis is aligned perfectly with the base of your housing.
Here are some pictures.
Hans
Boncuk is offline
Old 24th March 2008, 04:08 PM   (permalink)
well, my idea for keeping it simple would be along rolfs lines, with the bent plastic tube and the bearing. but instead of trying to engeneer the wire wraps and oscilators and such, id just put contacts it the tube at the pre-determined locations, and have each contact power the appropriate led.
deth502 is offline
Old 25th March 2008, 03:27 PM   (permalink)
If you haven't got a name for it - I got one: Improved eye ball system
Boncuk is offline
Old 29th March 2008, 03:46 AM   (permalink)
Security industry use Inertia sensors, if you can grab one of them from somewhere, it should do the job nicely. Alternately, RS have a sealed stainless steel mercury switch tilt switch?
bloke_man is offline
pan & tilt with basic stamp Othello Micro Controllers 6 22nd February 2008 10:20 PM
Pan and Tilt Platform with Memory! PLZ help:) Cynergy Micro Controllers 3 31st October 2007 10:13 PM
Xbox 360 Tilt Controller adamthole Electronic Projects Design/Ideas/Reviews 0 20th January 2007 06:24 PM
Ideas for a tilt sensor DannyBoy99 Electronic Projects Design/Ideas/Reviews 32 24th October 2006 07:42 PM
Replacement for mercury tilt switch zevon8 General Electronics Chat 19 7th November 2004 04:45 PM
