Old 21st March 2008, 01:19 AM   #1
Unhappy Help making 12v delay timer & warning buzzer in switch box
Hi folks,
Thanks for taking the rime to read this. As a mechanic i'm ohm's law & soldering/faultfinding literate in 12v apps as well as familiar with basic descreet componants eg resistor led capacitor etc.
I need some help making a little controller box to mount on the dash. it will need to run on 9-15v dc (12v-14.4v nominal automotive) unsmoothed.
It needs a single pole double throw switch (3 terminal) @ 5a to control the output, 4 led's that are easy to mount on box.
Now here is the interesting bit, I need a delay timer such that when switch is moved from position 2 to position 1, a 5a output is fed for an adjustable time between 1& 60sec. At a push the output could be nominal & drive a relay elsewhere. The time would need to not easily be tampered with, so recessed pot or removable cover to accesss dip switch needed. Also needs to have a small buzzer that sounds when switch is in position 2 and an input 12v is killed, ideally on a 20sec timer but i can live without that for simplicity sake, purpose is to warn driver if he turns ign off without switching unit to position 1.
Having 2 blade fuses accessable in side of unit would also be nice, or maybe under part flip or sliding cover with pot or dip switches.
whole unit must be small as poss, to fit on dash by other switches by sticky pad, 40mm high x 20mm deep x 80mm long i had in my head. 5 to 7 wires of 5a will be connected.
I have seen adjustable 'delay on break' relays for £25, they wouldnt fit in small box so i'd need a two part unit with timer under the dash - not so easy to adjust & harder to fit. besides i am hoping to make the whole thing under £25. other than timer its just leds, box, wire, switch, buzzer.
I may need a few & may be interested in paying someone to assemble for uk use. getting the design & sourcing seem the hard bits.
Can anyone help point me in the right direction please?
Greg.
greg123 is offline
Old 21st March 2008, 01:16 PM   #2
For simple timeing you can use a monostable 555 timer circuit.
If you want anything more complex then a microconrtoller is probably your best bet.
if I know the answer.
Hero999 is offline
Old 21st March 2008, 02:19 PM   #3
Thanks for that. I just need to be able to set it up between 1 and 60 seconds and it needs to handle input voltage of 9-15v. IT will need to switch a 10a output but obviously I can use it's output to trigger a relay. Will I need to make a circuit board? I have no kit to do that I guess I can research it.
Greg.
New to making electronic circuits but with a sound electrical/faultfinding and basic componant knowledge. Looking forward to learning!
greg123 is offline
Old 21st March 2008, 03:13 PM   #4
The delay can be varied from 1.1s to 67s.
The relay is already shown in the circuit will switch 10A providing you select one with the correct rating. Note that the 555 timer has a maximum output current of 200mA so don't choose a relay with a lower coil resistance than 75hm: or it'll cook the IC.
Hero999 is offline
Old 23rd March 2008, 12:40 AM   #5
Perfect, thanks. I'm gradually understanding it. I'm now selecting componants on RS - any particular type of resistor and capacitors I need? I have searched the web and can't find out what wattage resistor I need, I presume .25 watt is okay?
Also I note on the diagram it's a 9v supply, the 555 I have picked is said to work at 15v, 18v max - so that should be okay for my 12v - 14.4v nominal car voltage, but would that mean the resistor/capacitor values are going to be different?
Appreciate the help, I have ordered up a breadboard and some fly leads so pretty soon I should be tinkering!
Greg.
greg123 is offline
Old 23rd March 2008, 01:17 AM   #6
The resistor and capacitor values are the same regardless of the supply voltage.
0.25W resistors are fine. I tend to go for metal film myself, though carbon film will do fine.
TTL 555s will work from 4.5V to 15V, 16V maximum but some CMOS variaties will work up to 18V.
Hero999 is offline
delay, i12v, mechanic, needing, newbie, project, timer
Effects stephenpic Micro Controllers 6 19th January 2004 12:57 PM
Delay Circuit for Project (Help Needed) tewills Electronic Projects Design/Ideas/Reviews 2 6th November 2003 07:49 PM
newbie with a new project L0D|Mr_B Electronic Projects Design/Ideas/Reviews 3 15th October 2003 09:05 PM
My Halloween project - timer circuit? Anyone have any ideas? 2000boxster Electronic Projects Design/Ideas/Reviews 2 9th September 2003 05:29 PM
CMOS Timer Project? Newtronics Electronic Projects Design/Ideas/Reviews 10 11th August 2003 01:08 AM
